Want to use ios shortcut as trigger
Hi all, i am new in node red
and feel node's flow is so amazing
BTW, if it is possible to use IOS shortcut to trigger node red automation?
Thank you a lot for help
Yes that is possible, however you will most likely be depending on requests via http and outside the network you can't easily reach the node-red instance, unless you set it up (security/network wise)
dont know how to requests via http
please can you give an example, thanks so much
This is the general idea, in the shortcut, you can listen for voice input that can be passed on to a http request.
In node-red create an endpoint with a http-in/response node
Ofcourse, you don't have to listen for input (this is my use case), you can directly fire off a request that triggers something in node-red.
thank you so much for sharing your great idea
let me study in it :grinning:
