iOS 13 - Shortcuts
Hey guys,
I was watching a video from a german guy that used NFC tags to trigger events with iOS Shortcuts on ioBroker. https://www.youtube.com/watch?v=AUdZgZinHzo
Now I'm looking for a simple solution to achieve the same with node-red.
Has someone an idea to do this?
Thank you in advance.
EDIT: Ok found a solution that hopefully should work :slight_smile: http nodes should do the job. Can test it when my NFC tags arrive :slight_smile:
Yes, any of the nodes that present end-point url's should work just fine. http-in/out being possibly the simplest.
If you need them to work from outside your local network, you can use IFTTT as the link.
