Wanting to use a msg payload for blob name
I'm trying to upload a file to azure blob and wanting to name the blob based on a msg payload. I tried the below but the blob name ends up being {{{title}}}. How do I use a msg payload to fill out a property in a node?
I also tried the 3 curly brackets method with the write file node, but it creates the file as {{{title}}} instead of whatever is msg.title Imgur: The magic of the Internet
It will depend entirely in what the node supports.
Check the help sidebar for the node... It will hopefully document whether any of those properties can be set by message properties, and if so, what property you should use.
