I successfully installed Node Red on a Windows VM and it works.
Now I installed it on my Raspberry Pi and I always get the warning "Encrypted credentials not found" at startup and I cannot start any flows. I already tried to set/change the credentialsSecret, adminAuth and httpNodeAuth settings but that didn't change anything. Also also completely reinstalled the Raspberry OS and installed Node Red again. But nothing helps.
Any ideas?
Thank you
Can you stop and restart node red in a command window and post the full startup log here please. Copy/paste not screenshot please. You can stop it and restart using node-red-stop node-red-start
As you can see from the log the flows have been started. For some reason you have lost the credentials. That probably means that either the credentials secret in the pi is not the same as in the VM or you have not transferred the secrets file. To recover you can go to each of the nodes that have credentials in them and put them in again.
If you want to work out why it does not work then tell us exactly how you transferred the setup from the VM to the Pi, and in particular tell us how you have setup the credential secret in the VM.
[Edit] Also note these lines in the log
That means you have not copied the flows file across correctly. I suspect that you are not using the same version of node-red on the two systems. The default flows and credentials filename changed between versions at some point.
I did not try to transfer anything from my Windows PC. I do all on my Raspberry PI. And it seems to work (kind of) but I always get this warning. Also I get this warning in the debug window when restarting flows.
I just created a new flow and now the startup log looks like this:
Welcome to Node-RED
18 Jul 10:49:40 - [info] Node-RED version: v3.0.2
18 Jul 10:49:40 - [info] Node.js version: v16.20.1
18 Jul 10:49:40 - [info] Linux 6.1.21-v8+ arm LE
18 Jul 10:49:41 - [info] Loading palette nodes
18 Jul 10:49:44 - [info] Settings file : /home/admin/.node-red/settings.js
18 Jul 10:49:44 - [info] Context store : 'default' [module=memory]
18 Jul 10:49:44 - [info] User directory : /home/admin/.node-red
18 Jul 10:49:44 - [warn] Projects disabled : editorTheme.projects.enabled=false
18 Jul 10:49:44 - [info] Flows file : /home/admin/.node-red/flows.json
18 Jul 10:49:44 - [warn] Encrypted credentials not found
18 Jul 10:49:44 - [info] Server now running at http://127.0.0.1:1880/
18 Jul 10:49:44 - [info] Starting flows
18 Jul 10:49:44 - [info] Started flows
I added the credentialsSecret adminAuth and httpNodeAuth settings in the settings file.
To be honest contrary to my assumption all seems to work. So I am just curious about this message since it disappeared on my Windows installation of Node Red after making the mentioned settings.
I did not change configuration regarding filesystem. I am just using the original Raspberry Pi OS and installed Node Red.
After reboot my flows are still there.
I don't see a credentials file. Should it be located in ~/.node-red?
While Node Red is running the folder contains these files:
admin@raspberrypi:~/.node-red $ ls -a
. .config.users.json.backup node_modules settings.js
.. flows.json package.json
.config.nodes.json .flows.json.backup package-lock.json
.config.users.json lib .sessions.json
If the flow file that Node-red is using is ~/.node-red/flows.json then the credentials file should be ~/.node-red/flows_cred.json
Can you please show us the output of these commands?
