Water Tank Level Visualization
Hey Brains Trust,
I'm currently building a Water Tank monitoring for my oldies..
Trying to make a easy for them to understand with a easy visual representation on how full the water tank is.
Is there a way I can use this image below and fill in the picture with blue with the % giving from the data?
https://www.clipartmax.com/png/full/455-4555658_agua-clip-art.png
Json Data:
{"totalVolume":75030,"filledVolume":33634,"emptyVolume":41396,"usableVolume":75030,"usableFilledVolume":33634,"usableEmptyVolume":41396,"fillPercentage":45,"emptyPercentage":55,"usableFillPercentage":45,"usableEmptyPercentage":55}
Sonic/Ryan
Hi @s3m1s0n1c,
You want to cash in on the skills of @hotNipi,
and his work.
https://flows.nodered.org/user/hotnipi
Many examples of tanks/gauges etc etc on the forums created by @hotNipi
EDIT
See : Profile - hotNipi - Node-RED Forum
Thanks @marcus-j-davies
Will check it out :slight_smile:
Thanks Sonic
With such image it goes kind of complicated.
Simple but well readable with ui_template
<style>
    .wrapper{
        position: absolute;
        width: 90%;
        height: 90%;
        margin: auto;
        inset: 0;
        overflow:hidden;
        border-bottom-left-radius: 40px;
        border-bottom-right-radius: 40px;
    .txt{
        position: absolute;
        width: 100%;
        top: 45%;
        text-align: center;
        font-size: xx-large;
        font-weight: 700;
        user-select: none;
    .frame{
        position: absolute;
        width: 100%;
        height: 100%;
        margin: auto;
        inset: 0;
        outline: 5px solid;
        outline-offset:-5px;
    .fluid{
        position: absolute;
        width: 100%;
        height: 100%;
        bottom: 0;
        background: #00a8ff;
</style>
<div class="wrapper">
    <div class="fluid" style="height:{{msg.payload}}%"></div>
    <div class="frame"></div>
    <div class="txt">{{msg.payload}}%</div>
</div>
That is Awesome @hotNipi
That will work great...
Thank you :slight_smile:
Hi @s3m1s0n1c,
There is no way on earth I can beat the widgets from @hotNipi ...
But just for completeness, I have written a tutorial recently about partially filled shapes using SVG. But yes, not as fancy as the example above.
Bart
It should be noted for others looking at complicated shapes that CSS can do image masking and there are good resources out there for it:
With that area of CSS the one should then accept all the challenges with older (most commonly IOS) browsers/devices thus it is common to have some old screens dedicated to display some kind of home dashboard.
This reminds me of the recent discussion on using colour to show temperature at different levels in a tank.
I'm pondering CSS color/transparency for the different levels as a different approach.
It would be interesting to compare the different approaches to display the level in @s3m1s0n1c's tank image.
Hmm. If Apple wanted me to design for Safari, they'd port it to Linux and Windows like they used to!
If you want it even easier to implement, you can consider the round gauge widget. I use it for chemical tanks:
Built in Default Level guage in dashboard.
[{"id":"4b438d01afcd708b","type":"inject","z":"ae4889735061574b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"10","payloadType":"num","x":320,"y":180,"wires":[["c54d2bc07606309c"]]},{"id":"6164a0cc4a012d60","type":"ui_gauge","z":"ae4889735061574b","name":"","group":"833d4cbc08a98b24","order":1,"width":6,"height":6,"gtype":"wave","title":"Tank Level","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":520,"y":130,"wires":[]},{"id":"7eb1fd6f85e4421a","type":"ui_slider","z":"ae4889735061574b","name":"","label":"slider","tooltip":"","group":"833d4cbc08a98b24","order":5,"width":0,"height":0,"passthru":true,"outs":"all","topic":"topic","topicType":"msg","min":0,"max":"100","step":"5","className":"","x":320,"y":130,"wires":[["6164a0cc4a012d60"]]},{"id":"c54d2bc07606309c","type":"ui_gauge","z":"ae4889735061574b","name":"","group":"833d4cbc08a98b24","order":2,"width":6,"height":6,"gtype":"wave","title":"Tank Level","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":520,"y":180,"wires":[]},{"id":"2e33dbd4517886c8","type":"ui_gauge","z":"ae4889735061574b","name":"","group":"833d4cbc08a98b24","order":3,"width":6,"height":6,"gtype":"wave","title":"Tank Level","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":520,"y":230,"wires":[]},{"id":"b76a8be3c49ce517","type":"ui_gauge","z":"ae4889735061574b","name":"","group":"833d4cbc08a98b24","order":4,"width":6,"height":6,"gtype":"wave","title":"Tank Level","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":520,"y":270,"wires":[]},{"id":"d9965b0e9227255f","type":"inject","z":"ae4889735061574b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"25","payloadType":"num","x":320,"y":230,"wires":[["2e33dbd4517886c8"]]},{"id":"89415e06023639e7","type":"inject","z":"ae4889735061574b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"75","payloadType":"num","x":320,"y":270,"wires":[["b76a8be3c49ce517"]]},{"id":"833d4cbc08a98b24","type":"ui_group","name":"LEVEL","tab":"fb48ae21810a7ddc","order":3,"disp":false,"width":24,"collapse":false,"className":""},{"id":"fb48ae21810a7ddc","type":"ui_tab","name":"TEST","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
Nice! I'll give it a try too! :slight_smile:
I ended up using @hotNipi's example..
I tried doing some like @smanjunath211 but likes @hotNipi 's better
Luvin all the discussion tho..
Glad you could solve your issues
