Ways to fine-tune widget layouts and spacing?
I've got two types of widgets next to one another (a gauge and a pie chart), and their layout issues are driving me crazy. I've tried every adjustment I can imagine to their individual sizes, the 1x1 unit sizes/proportions, group padding and spacing, etc. etc. Still, one has a lot more margin than the other, and the titles don't line up.
Here's the closest I've been able to get them - every other permutation has been worse:
widgetLayout
Is there a way to get under the hood and make tweaks to the widget layouts to get the titles to line up at least, or to do widget-specific padding/spacing rules? Sorry if that's kind of a tall order, but I don't know where to look for more settings at this point.
(Also if anybody knows a good way to get a % sign to appear to the right of the number in the mouseover box, that'd be great, too, but less important.)
Labels of widgets are no individually addressable but still you can reach them by using :nth-child(count)
I made a little example how you can add and modify the CSS of elements. Play with it and find the way to make something similar for your dashboard.
[{"id":"7959eb78.619374","type":"ui_gauge","z":"94f3e22a.5d351","name":"GA","group":"f7080b8f.ec7f98","order":0,"width":"3","height":"3","gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":450,"y":400,"wires":[]},{"id":"69fdf769.e8c6b8","type":"inject","z":"94f3e22a.5d351","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"a","payload":"5","payloadType":"num","x":250,"y":240,"wires":[["14a4f120.81cb4f","83499a0d.7ad408"]]},{"id":"39ef8c05.3aadc4","type":"inject","z":"94f3e22a.5d351","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"b","payload":"7","payloadType":"num","x":250,"y":280,"wires":[["83499a0d.7ad408"]]},{"id":"a7c6c763.d9f548","type":"inject","z":"94f3e22a.5d351","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"c","payload":"9","payloadType":"num","x":250,"y":320,"wires":[["83499a0d.7ad408"]]},{"id":"14a4f120.81cb4f","type":"random","z":"94f3e22a.5d351","name":"","low":"1","high":"10","inte":"true","property":"payload","x":270,"y":400,"wires":[["7959eb78.619374","df881864.228348"]]},{"id":"83499a0d.7ad408","type":"ui_chart","z":"94f3e22a.5d351","name":"","group":"f7080b8f.ec7f98","order":1,"width":"3","height":"3","label":"chart","chartType":"pie","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":"70","useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":450,"y":280,"wires":[[]]},{"id":"9312028f.112a5","type":"ui_template","z":"94f3e22a.5d351","group":"f7080b8f.ec7f98","name":"alignement of labels","order":2,"width":0,"height":0,"format":"<style id=\"tweak-labels\">\n/*\nfirst element in card (from left to right). change of label padding (changes whole chart element vertical position)\n*/\n#Home_default_cards > md-card:nth-child(1) > div > p{\n    padding-top:0px;\n}\n/*\nsecond element in card (from left to right). change label margin.\n*/\n #Home_default_cards > md-card:nth-child(2) > p.label.nr-dashboard-gauge-title.ng-binding{\n    margin: 3px 0px 0px 0px;\n}\n/*\nthird  element in card (from left to right) is left unchanged just to preserve original look for comparsion.\n*/\n\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":500,"y":520,"wires":[[]]},{"id":"df881864.228348","type":"ui_gauge","z":"94f3e22a.5d351","name":"GA2","group":"f7080b8f.ec7f98","order":0,"width":"3","height":"3","gtype":"gage","title":"Another ga","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":450,"y":440,"wires":[]},{"id":"f7080b8f.ec7f98","type":"ui_group","z":"","name":"default","tab":"cecac48e.2a6aa8","order":1,"disp":true,"width":"9","collapse":false},{"id":"cecac48e.2a6aa8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
