Weather-icons in dashboard
I am using the weather icons ( git clone GitHub - Paul-Reed/weather-icons: Node-red weather icons) in a dashboard and everything works fine, except the fa-2x wi wi-wind-beaufort-4 icon. Did someone else had the same problem with this icon? I have checked everything and can't find any problems in the CSS and Font files.
Any help is welcome and I am very happy with all the other icons.
Thanks in advantage
Ino
https://github.com/Paul-Reed/weather-icons.git was marked 'Do not use' 6 years ago!
Sorry, but it is no longer maintained, especially as node-red dashboard has been superceded by dashboard-2, which doesn't use 'weather icons'.
thanks for the answer; didn't read it. Go to install dashboard 2
dashboard 2 has built-in access to Material Design Icons library as detailed here: UI Template Examples | Node-RED Dashboard 2.0 which has some reasonable weather icons built in.
Thanks, I switched to dashboard 2 and now I am trying to get familiar with the UI template. I hope I can find some examples of dashboard 2 witch the use of icons
Here is a link to what icons are available - Material Design Icons - Icon Library - Pictogrammers
(this is MD v7.4.47 which is what is installed in dashboard-2, unless it's recently been updated).
