I was using this...
To get this
I was using this...
To get this
Yeah, me too. That works.
But there is the real message and when it is received it doesn't show the correct icon.
Are you sure that the real payload is same as for your local test case?
Thanks @hotNipi .
I did a similar one.
This is my result.
Icons are left to right top to bottom. 14 in all and they match their names.
I've posted them both a few times.
This one works.
{"_msgid":"d047a6b4.50df08","payload":"wi wi-snow","topic":"","colour":"white"}
This one doesn't change the icon.
{"payload":"wi wi-darksky-snow","event":{"clientX":975,"clientY":198,"bbox":[947,225,995,177]},"socketid":"avA216tBMV5ZI5RaAABP","_msgid":"1b1c15b9.df39fa","icon":"<i class=\"fa fa-refresh fa-spin\"></i>","background":"#333333","font":"red","location":{"lon":149.1333,"lat":-36.2333,"city":"Cooma","country":"AU"},"data":{"coord":{"lon":149.1333,"lat":-36.2333},"weather":[{"id":601,"main":"Snow","description":"snow","icon":"13d"}],"base":"stations","main":{"temp":272.02,"feels_like":268.21,"temp_min":272.02,"temp_max":272.02,"pressure":1016,"humidity":100},"visibility":10000,"wind":{"speed":3.09,"deg":30},"snow":{"1h":0.87},"clouds":{"all":100},"dt":1626647713,"sys":{"type":1,"id":9520,"country":"AU","sunrise":1626642594,"sunset":1626678551},"timezone":36000,"id":2170577,"name":"Cooma","cod":200},"time":"2021-07-18T22:35:13.000Z","title":"Current Weather Information","description":"Current weather information at coordinates: -36.2333, 149.1333","base":{"wind":{"light":10,"strong":40}},"_event":"node:1ac83a63.8be8e6","now":1626683657,"colour":"white"}
But that's because it has the other weather data in it.
If you don't mind, post the code you have in those nodes and I will post a similar screen shot.
[{"id":"5f289ce3.7637e4","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1640,"wires":[["c8e1640e.1203e8"]]},{"id":"c8e1640e.1203e8","type":"change","z":"407e1abc.6d1cb4","name":"Darksky cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-cloudy\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":1640,"wires":[["8a79a988.35e4d8"]]},{"id":"8a79a988.35e4d8","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1640,"wires":[[]]},{"id":"c3d3fd02.d24fc","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1690,"wires":[["ebf82944.b8ba18"]]},{"id":"ebf82944.b8ba18","type":"change","z":"407e1abc.6d1cb4","name":"Dark sky rain","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-rain\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1690,"wires":[["9200f8fc.dfec48"]]},{"id":"32ad102b.024d8","type":"change","z":"407e1abc.6d1cb4","name":"Dark sky hail","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-hail\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1740,"wires":[["7a8d85c3.df334c"]]},{"id":"2d3317a8.752b58","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1740,"wires":[["32ad102b.024d8"]]},{"id":"59bae66b.269f48","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1790,"wires":[["cee52dad.5d757"]]},{"id":"cee52dad.5d757","type":"change","z":"407e1abc.6d1cb4","name":"Dark sky thunderstorm","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-thunderstorm\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":1790,"wires":[["832f36d7.c15028"]]},{"id":"f1201002.7acde","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1840,"wires":[["d66ee233.a5de8"]]},{"id":"d66ee233.a5de8","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-darksky-partly-cloudy-day\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1840,"wires":[["3d3e4f89.fbc28"]]},{"id":"677d7c79.c77014","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1890,"wires":[["2634239a.75ab7c"]]},{"id":"2634239a.75ab7c","type":"change","z":"407e1abc.6d1cb4","name":"Dark sky rain","rules":[{"t":"set","p":"payload","pt":"msg","to":"<i class=\"wi wi-wu-rain\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1890,"wires":[["b00bc61c.85b4b8"]]},{"id":"28f757da.d4d718","type":"change","z":"407e1abc.6d1cb4","name":"Sunny day","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-darksky-clear-day\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1940,"wires":[["14b81f34.06e801"]]},{"id":"deb5fc29.1fc9b","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1940,"wires":[["28f757da.d4d718"]]},{"id":"86a3df2e.2aa71","type":"change","z":"407e1abc.6d1cb4","name":"Dark sky fog","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-darksky-fog\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1990,"wires":[["bc682431.faf658"]]},{"id":"9e5ca7ac.c54918","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":1990,"wires":[["86a3df2e.2aa71"]]},{"id":"8fedffdc.f424a","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-wu-partlycloudy\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2040,"wires":[["506145f2.11f41c"]]},{"id":"74c80a0a.389054","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2040,"wires":[["8fedffdc.f424a"]]},{"id":"ea0d5d0.ba023a","type":"change","z":"407e1abc.6d1cb4","name":"Mostly sunny","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-wu-mostlysunny\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2090,"wires":[["a8a2ce89.af0fe"]]},{"id":"4121054f.35117c","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2090,"wires":[["ea0d5d0.ba023a"]]},{"id":"430f17d5.e6ea48","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-wu-partlycloudy\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2140,"wires":[["38551f7.89c82e"]]},{"id":"6ad793d.1df4e6c","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2140,"wires":[["430f17d5.e6ea48"]]},{"id":"c0887a3b.69b3f8","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-wu-partlycloudy\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2190,"wires":[["97c6a47a.2b1678"]]},{"id":"ea8d56d6.14fe38","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2190,"wires":[["c0887a3b.69b3f8"]]},{"id":"fc687aac.433868","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-day-fog\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2240,"wires":[["526b018c.ff11"]]},{"id":"8128f81c.79bf18","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2240,"wires":[["fc687aac.433868"]]},{"id":"276843ae.d37edc","type":"change","z":"407e1abc.6d1cb4","name":"Partly cloudy","rules":[{"t":"set","p":"payload","pt":"msg","to":" <i class=\"wi wi-snow\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":2290,"wires":[["f2d4ba6f.0025f8"]]},{"id":"6a0b774a.d21c18","type":"inject","z":"407e1abc.6d1cb4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":2290,"wires":[["276843ae.d37edc"]]},{"id":"9200f8fc.dfec48","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1700,"wires":[[]]},{"id":"7a8d85c3.df334c","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1740,"wires":[[]]},{"id":"832f36d7.c15028","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1780,"wires":[[]]},{"id":"3d3e4f89.fbc28","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1840,"wires":[[]]},{"id":"b00bc61c.85b4b8","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1900,"wires":[[]]},{"id":"14b81f34.06e801","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1940,"wires":[[]]},{"id":"bc682431.faf658","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":1980,"wires":[[]]},{"id":"506145f2.11f41c","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2040,"wires":[[]]},{"id":"a8a2ce89.af0fe","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2100,"wires":[[]]},{"id":"38551f7.89c82e","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2140,"wires":[[]]},{"id":"97c6a47a.2b1678","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2180,"wires":[[]]},{"id":"526b018c.ff11","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2240,"wires":[[]]},{"id":"f2d4ba6f.0025f8","type":"ui_template","z":"407e1abc.6d1cb4","group":"50e5ef3c.86993","name":"","order":1,"width":3,"height":"3","format":"<span>{{msg.payload}}</span>\n<div style=\"font-size: 48px;\"\n ng-bind-html=\"msg.payload\">\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":600,"y":2300,"wires":[[]]},{"id":"50e5ef3c.86993","type":"ui_group","name":"Group 2","tab":"de0f6b36.132fa8","order":5,"disp":true,"width":"17","collapse":true},{"id":"de0f6b36.132fa8","type":"ui_tab","name":"Weather","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Andrew, the one that works you show as wi wi-snow and the one that doesn’t is wi wi-darksky-snow which is a different name and different sets of icons.
Meanwhile @Gunner was using a third set (the wu set I.e. weatherunderground.
You should try to only use one set of icons so as not confuse yourself/
Yeah, I was told that there is no real difference between wi wi-snow and wi wi-darksy-snow.
I can make it wi wi-snow if you want. But that is what it was originally and it doesn't work.
You can use which ever you want. I’m just suggesting you only use one to keep things simple.
Believe me, I do do that.
This is the.... progression of a bad life cycle.
I started of with a flavour (name) and when it stopped working, I used alternative names.
If they work/ed I moved on.
Though maybe upgrading all previous ones to the newer names may in itself open a can of worms.
When I get it all working, I may do that. But just now it is trying to establish which is the best name/set to use.
Thanks.
Just the first line with the <span>{{msg.payload}}</span> would have sufficed.
But anyway, this is my test icon set.
So as you can see, they all work.
But I'm not sure if we are missing the question to why it doesn't work when I put the snow message into the template node when it has the rest of the weather message.
It goes through the node and comes out. No errors. Just the icon isn't changed.
For sure we are on different platforms and different browsers so there is things what can cause differences. Cos as I see you have wi wi-snow in those conditions.
Thing you haven't shown yet is the actual case inspected with developer tools like I did in post 9
Sorry... I am really REALLY new to those things.
I can't just use them.
I will try to do it, but as another thought: I will load another browser and see what happens with it as an apples with apples case.
More coming soon.
Different browser... Same.
Developer tools....
I'm not sure it is going to help, as that shows what's on the screen - yes?
I clicked on the icon which should have changed, but it hasn't / didn't... So I am not sure what it is telling you.
To be clear: I clicked on the right side of the screen on the part which shows the moon behind clouds.
But that is what the weather is in real time.
I clicked the inject node that injects the message with snow in it, and it comes out the other side of the node... Just the icon isn't changed.
Sorry, but you may need me to click / select other things in the middle and right of the developer tools window.
But as I said: The icon isn't changed, so I am at a loss how this is helpful.
Not quite sure what you mean by that comment...
All of those shown should be functional, but if not, these please let me know...
It is a shame I can't drag select stuff from the left side of the developer tools window and past them here.
I can't work out how to.
I'm sure it goes for wi-wu-snow but not for wi-snow. Cos for me it is what the mapping says.
Only because it was really getting to me, I changed the location to somewhere which will be getting more snow.
Changed the place, ran the code, got snow and the icon works.
Sorry.
Dunno what is going on.
It isn't fair to continue now the flow/code is behaving itself.
Sorry folks.
And thanks to all anyway.
