Weather Word Descriptions from Dew Point, Temperature, VOC & Tado (Simple Air Comfort Card)
LINK TO FLOW HERE
Putting words to what it feels like
This flow converts numeric temperature and humidity values into text descriptions. Makes them available in Home Assistant and use in Simple Air Comfort Card or other Custom Cards.
It contains 5 methods.
  • TADO COMFORT TEXT DESCRIPTION (TADO API)
    • Humidty DRY, COMFY, HUMID
    • Temperature COLD, COMFY, WARM
    • Gets the words from Tado API, Funtion Node filters based on payload address.
    • Requires node-red-tado-client to extract the text description from the Tado API
    • Requires Node-RED Companion Integration
  • HUMIDITY COMFORT TEXT DESCRIPTION (NON TADO DEVICES)
    • Humidty , DRY(<39.9%),(40%)COMFY(59.9%)**, HUMID(>60%) (Same as Tado)
    • Switches Temperatures to words based on the above values. msg.topic changes the words
    • Requires any Temperature Sensors.
  • TEMPERATURE COMFORT TEXT DESCRIPTION
  • VOC TEXT DESCRIPTION
    • VOC ppm Changes words based on the below values:
SIMPLE AIR COMFORT CARD
THE DESCRIPTIONS CAN BE USED AS A TEXT DESCRIPTION IN THE
CODE FOR TABLET AND PHONE VERSIONS CAN BE FOUND HERE
Inside Colour Scale for Dewpoint Comfort, Background Colour Scale for Temperature Comfort
THIS IS USED TO CONNECT TO THE TADO API AND GET THE TEXT DESCRIPTION FOR THE TEMP AND HUMIDITY.
TADO Temp(COLD,COMFY,WARM) - Humidity (DRY,COMFY,HUMID)
REQUIREMENTS: node-red-contrib-tado-client
TADO [getMe] Node Setup
  1. Double Click Tado [getMe] Node, Add a New Tado Config...
  2. Enter your TADO Account login details into the config.
  3. Click Done.
  4. Click the Inject Node timestamp.
  5. Find your homes ID in the debug message [window payload.homes[0].id]
TADO Other Nodes
  1. Enter your Home ID into the other Nodes to fetch information from the API
  2. Click the time stamp into the Tado [getAirComfort] Node
  3. Find the path >_Copy Path Button in the Debug Node [payload.comfort[0].temperatureLevel]
Function Node
  1. Copy the path above into the Function Node
  2. CLICK the Inject Node timestamp to Test
  3. Your sensor should display the text and be in home assistant, updated every 1 minute.
DEWPOINT COMFORT TEXT DESCRIPTION
  1. INSTALL DewPoint Sensor Calculator via HACS
  2. You will have to add as a Custom Repository using the 3 Dot menu top right in HACS.
  3. CLICK INTEGRATIONS in HACS
  4. CLICK 3 button menu top right
  5. CLICK Custom Repositories
  6. PASTE GitHub - miguelangel-nubla/home-assistant-dewpoint: Home Assistant custom component to calculate dew point using temperature and humidity sensors. in the Repository Field
  7. SELECT Integration in the Category field
  8. CLICK ADD
  9. RESTART HOME assistant
  10. Setup your sensors in your configuration.yaml file.
sensor:
  - platform: dewpoint
    sensors:
      dewpoint_outside:
        temperature: sensor.temperature_outside
        rel_hum: sensor.humidity_outside
      dewpoint_office:
        temperature: sensor.temperature_office
        rel_hum: sensor.humidity_office
  1. Insert your dewpoint sensor in the 'Current State' Node
  1. Insert your temperature sensor in the 'Current State' Node
VOC COMFORT DESCRIPTION
HUMIDITY COMFORT DESCRIPTION (NON TADO DEVICES)
Very nice thanks - you might also want to cross post onto the Home Assistant Forum (they have a specific NR subforum)
Craig
Yes posted in there ages ago, now just cross posting over to here. Also now added a link to the flow I have uploaded.
