Web Server - for my customers?
Hello: I'm looking for suggestion on how I need to get this done.
I have a new project and this is what I need to make happen.
I'm using Mqtt as my communication protocol.
So this is what I'm doing.
I have a job that only runs for 36 hours, during that job I want to collect (to a database - every 2 minutes) and display 2 variables (Pressure, Flow Rate). I can do all this now with my Ignition SCADA Server. BUT I would like to have a web page that my customers can log into and see this live data and I want some type of a TREND for the data being recorded.
Does anybody have any recommendations?
MQTT does not really have anything to do with a website.
As far as Node-RED goes, you can tweak settings.js and put a user/pass on the dashboard.
I think most here would recommend a VPN only access for your customers.
If the number of customers is very low, and the dashboard is very simple (caution with the trends), then it should be a pretty quick build using either dash 1 or dash 2 nodes. (Depends on if you need responsive pages or not).
What PLC is behind this?
Thanks for the Info.
Allen Bradley Micro-820 plc.
:backhand_index_pointing_up:
Always!!!
Node RED - is a target for hackers, so please use the strongest/safest methods possible.
If you search these forums - you will find many (unfortunate) stories of Node RED being hacked, and by extension - the systems it is attached to.
Its not a weakness of Node RED - more so the user implementing it, and foolishly exposing it to the public, without implementing the correct security measures.
See : Safely accessing Node-RED over the Internet
In essence - Don't open Port 1880, and instead create a tunnel for specific source connections.
You could go with a Node-RED provider that has spent the last 3 years developing a secure by default way of hosting node-red. like, for example FlowFuse. Everything is done for you.
Thanks, I will look into this. This is what I was hoping for. Sounds like this might work for my needs. Will keep you posted.
What about using "reverse proxy" service like "Ngrok" or "LocaltoNet" as VPN tends to be slower?
