Websocket close, does not connect
I configure a CP client JSON but I can't connect to the server on the Internet.
I have checked that the url is correct and I try to send a bootnotification with the connection but does not connect and in the server I dont have any log.
I have tried to connect with websockets in python and it connects correctly.
Can you give me some idea how to get connected, do you know how I can look at the exact parameters it is sending to connect?
thanks for your help I am new with node red
Sorry, I don't know what that means.
Again, not clear what that means I'm afraid.
If this is working then clearly your other connection is the problem and not node-red. You will need to be able to descript what that connection is in greater detail.
I had a problem with the handshake. thanks for your help.
