Weird all my icons (associated with ui buttons) in dashboard 2.0 show now is just an outline of a square? I have stop and restarted NR, the flows have not changed. Using MDI icons of course. No errors or such in the NR log.
Make a test flow using a raw template node just to illustrate the issue...
[{"id":"018307a92f650a6c","type":"tab","label":"Test","disabled":false,"info":"","env":[]},{"id":"46d3aa3ad7f3da7c","type":"ui-template","z":"018307a92f650a6c","group":"08cb4840d3262197","page":"","ui":"","name":"","order":0,"width":0,"height":0,"head":"","format":"<template>\n <div class=\"d-flex align-center ga-2\">\n <v-icon color=\"primary\" size=\"large\">mdi-lightbulb-outline</v-icon>\n <span>Status Normal</span>\n </div>\n</template>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":760,"y":340,"wires":[[]]},{"id":"08cb4840d3262197","type":"ui-group","name":"Test","page":"a129af50497c821b","width":6,"height":1,"order":-1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"a129af50497c821b","type":"ui-page","name":"Dachshund Digital","ui":"b9d115efa0ea05a2","path":"/Casitas","icon":"home","layout":"grid","theme":"eae0f4a4353a3ec9","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":true,"disabled":false},{"id":"b9d115efa0ea05a2","type":"ui-base","name":"Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true,"allowInstall":false},{"id":"eae0f4a4353a3ec9","type":"ui-theme","name":"Dark","colors":{"surface":"#008080","primary":"#008080","bgPage":"#000000","groupBg":"#000000","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}},{"id":"8be3eb4fc2f319db","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.30.2"}}]
Result...
Does not matter what ui node I use, what icon I use, all broken in the same way.
Node Red 5.0
PiOS 13 fully patched
Node 25.2.1
