What am I doing wrong? (multiple outputs from function)
msg.payload = true;
return [ msg, null ];
Why does my function only have one output?
Even with two message objects, I still only get one output:
var msg1 = {};
var msg2 = {};
msg1 = true;
msg2 = false;
return [msg1 , msg2];
You manually add the outputs at the bottom of the function node.
I knew it would be something that simple.
I didn't see it because the bottom lines of my screen is covered by my password manager information bar. Normally I can go to full-screen to see whatever is there, but not this time.
oops
