What is event name of Configuration nodes update?
Hi all,
I had created my main created node, and it call configuration nodes. Now configuration node can open and editable. But I want to control configuration when [Update] button of configuration node is clicked.
I try to use
oneditsave: function () {
but it had not raised this event.
What is event name of Configuration nodes update? :thinking:
It is the same as regular nodes - oneditsave.
If you aren't seeing it get called, something else must be wrong with your node.
Thank you so much for your reply :blush:
I missed something in my code. So now, it work.
