I installed a Docker based Node-Red on the ARM v7 architecture in the Ubuntu system,
It was found that in the Docker, there is a file space occupying a large amount (/usr/src/node-red/core, size 593.1M),
What is the purpose of this file and why does it take up so much space? Can its space occupation be reduced?
It looks like a core dump file following a crash - the timestamp is much more recent than anything else.
Is this a newly created container? What image are you using exactly?
I installed a Docker based Node-Red using the following command,created approximately a month ago:
docker run -v /node_red_data:/data --group-add dialout -p 1880:1880 --privileged=true --restart=always --name mynodered -u root:dialout nodered/node-red
【A core dump file following a crash】
- What content will be included and under what circumstances will the file be updated?
Thank you for your guidance
The file is generated by the OS when a process crashes. I don't know all the specific scenarios that can happen in this particular case.
It will include a full snapshot of the process memory and other things to help debug the crash - this is a standard linux thing, nothing specific to Node-RED.
You can delete the file - Node-RED doesn't use it.
Thank you for your great help
