What is wrong with this function code?
From everything I've been able to find this code in a function in a subflow should produce 2 output connectors, the 2nd for the subflow status to connect to. But there is only 1 connector.
if (isNaN(msg.payload)) {
    node.warn("Input is NaN");
    msg.payload = "";
} else {
    msg.payload = ((msg.payload * 9 / 5.0) + 32).toFixed(1)
let statusMsg = { fill: "green", shape: "dot", text: "`${msg.payload.toString}°F`" };
var newMsg = { payload: statusMsg };
return [msg, newMsg];
Yes, I know that the construction of statusMsg is probably wrong but first things first.
You have to increase the number of outputs in the function node.
Thank you!!! Didn't even think to look in there.
