Hi folks,
Would like to support Joe a bit solving one of the 300+ dashboard issues, but lacking some VueJs knowledge unfortunately:
I have added some methods to the ui-template node, and want to use those in the created() hook:
methods: {
setupHead() {
parseHeadElements() {
created() {
this.$dataTracker(this.id);
this.parseHeadElements()
this.updateTemplate()
But that fails because the methods seem to have not been binded yet to this:
TypeError: this.parseHeadElements is not a function
at Proxy.created (index-BRXhQldV.js:246:5488)
at callWithErrorHandling (index-BRXhQldV.js:17:2136)
at callWithAsyncErrorHandling (index-BRXhQldV.js:17:2244)
at callWithAsyncErrorHandling (index-BRXhQldV.js:17:2400)
at callHook$1 (index-BRXhQldV.js:17:24414)
at applyOptions (index-BRXhQldV.js:17:23477)
at finishComponentSetup (index-BRXhQldV.js:17:74881)
at setupStatefulComponent (index-BRXhQldV.js:17:74013)
at setupComponent (index-BRXhQldV.js:17:73411)
at q (index-BRXhQldV.js:17:46071)
However Joe's dashboard methods seem to have been binded already to the proxy object:
From e.g. this StackOverflow discussion I assume that method binding happens in the lifecycle before the created hook has been called?
Hopefully anybody can see what I am doing wrong, because I have no clue at all.
Thanks!!
Bart
For me the dev tools says
That makes sense since the Vue app will likely have run through its created and mounted phases long before the template reaches it.
Ah yes confusing indeed. Will need to explain it in more detail.
I have added my code snippet above to the core ui-template node code (at this location), not inside the ui-template config screen like the users do. Because I am trying to fix a reported issue in the ui-template node core code. I am not trying to add that code snippet inside the editor of the ui-template node config screen.
So my created() hook (in the core ui-template node code) is being called, and inside this hook I want to build the DOM subtree (as specified by the user in the config screen).
So the created() hook of the ui-template core code is called in my debugger, but the this does not contain the functions which I had added to the methods section. Hopefully that describes my problem a bit better.
Sorry, beyond my knowledge level of Vue.
They should be: vue docs
How did you determine they were "not there" Bart?
try console logging them e.g:
created() {
console.log("this", this)
console.log("this.parseHeadElements", this?.parseHeadElements)
console.log("this.updateTemplate", this?.updateTemplate)
Also, did you rebuild after modifying? I often have issues with source maps (yuk). Try modifying the vite.config.js to provide non minified, full source.
build: {
// Generate a source map in dev mode
// sourcemap: process.env.NODE_ENV === 'development',
minify: process.env.NODE_ENV === 'development' ? false : undefined,
outDir: '../dist',
emptyOutDir: true
and of course, run npm run build:dev or npm run dev for hot reload
@Steve-Mcl,
Thanks for your assitance (and time)!
I determined the functions where not there because (see my original post above) calling them in the created() hook results in a nasty stack trace.
Yes done a couple of rebuilds, refreshed my browser, ...
Here you can see the same result with your not-minified code and console statements:
@Steve-Mcl
Think I found it
Have not tested it yet, but I think that will be the root cause.
I have two times methods: defined in my vue file: one time for the existing methods and one time for my new methods. Don't think that Vue will like that...
Sorry for the noise!!!
@Steve-Mcl,
Is there a particular reason why your build config is not in the standard vite.config.js file? Because together with that npm run build:dev command that seems to be working very nice. Such commands would be a welcome addition to the dashboard contribution docs, for people like me (who don't work with Vue in their daily jobs). Thanks for sharing your tips!!! Very useful...
Only because I am in the middle of the wysiwyg stuff and I am not in a simple position to switch branch and propose it. You hit lucky (timing wise) as I only just yesterday got sick of source maps being out of step and looked for alternative (which is what i proposed to you).
If your env is in a better state than mine, feel free to propose a change.
EDIT: done - Improve DX - dont minify dev build by Steve-Mcl · Pull Request #1471 · FlowFuse/node-red-dashboard · GitHub
