Why does my Node-RED take too long to load
Welcome to Node-RED
14 Aug 05:36:01 - [info] Node-RED version: v1.3.5
14 Aug 05:36:01 - [info] Node.js version: v10.16.3
14 Aug 05:36:01 - [info] Windows_NT 10.0.19041 x64 LE
14 Aug 05:38:02 - [info] Loading palette nodes
14 Aug 05:49:45 - [info] Dashboard version 2.30.0 started at /ui
14 Aug 06:31:01 - [info] Settings file : C:\Users.node-red\settings.js
14 Aug 06:33:06 - [info] Context store : 'default' [module=memory]
14 Aug 06:33:06 - [info] User directory : \Users.node-red
14 Aug 06:33:06 - [warn] Projects disabled : editorTheme.projects.enabled=false
Hello and welcome to the forum.
To answer your title with as much detail as is possible... based on your supplied detail...
"Because something is slow" :stuck_out_tongue:
For the expanded version of that answer we would need to know a lot more about what your node-red is running on (although that looks like Windows 10, clarification of details would be nice), when this started (EG. after you changed something?), what have already tried to troubleshoot, more detailed logs, and so on...
Also, have you searched the forum for similar issues? Here is an older reference
Also try setting the log level to trace in settings.js. that may help to identify where the delay is.
Hello Gunner, thank you!
Yes, I am running it on Windows 10. I don't think I changed anything but after running MQTT and CoAP that's when I noticed it getting slow.
Thank you, i'll check out the forum
