Why Node-red debug node doesn't show my MQTT message?
Hi guys, I'm trying to send data from my Wemos to Node-red via MQTT. I created a nested object I want to send to MQTT. From the serial of Arduino IDE the output is this:
[{"AcX":-1,"AcY":-1,"AcZ":-1},{"AcX":-1,"AcY":-1,"AcZ":-1},{"AcX":-1,"AcY":-1,"AcZ":-1},{"AcX":-1,"AcY":-1,"AcZ":-1},{"AcX":-1,"AcY":-1,"AcZ":-1}]
It seems all correct but the debug node show nothing
Here's the code:
//LIBRARY
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <PubSubClient.h>
#include<Wire.h>
//JSON Array and mqtt data
#include <ArduinoJson.h>
#define MQTT_BUFFER 512
//MPU
const int MPU = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ;
// IP adress Raspberry Pi
const char* mqttServer = "raspi";
const int mqttPort = 1883;
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
  //MPU
  Wire.begin();
  Wire.beginTransmission(MPU);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  //SERIAL
  Serial.begin(115200);
  // WiFiManager
  // Local intialization.
  WiFiManager wifiManager;
  // Uncomment and run it once, if you want to erase all the stored information
  //wifiManager.resetSettings();
  // set custom ip for portal
  //wifiManager.setAPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  // fetches ssid and pass from eeprom and tries to connect
  // if it does not connect it starts an access point with the specified name
  // here  "AutoConnectAP"
  // and goes into a blocking loop awaiting configuration
  wifiManager.autoConnect("AutoConnectAP");
  // if you get here you have connected to the WiFi
  Serial.println("Connected.");
  //server.begin();
  //CLIENT
  client.setServer(mqttServer, mqttPort);
  client.setCallback(callback);
  server.begin();
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived in topic: ");
  Serial.println(topic);
  Serial.print("Message:");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  Serial.println("-----------------------");
//RECONNECT FUNCTION
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("esp8266")) {
        Serial.println("connected");
        // Once connected, publish an announcement...
        //client.publish("outTopic", "hello world");
        // ... and resubscribe
        //client.subscribe("inTopic");
    } else {
        Serial.print("failed, rc=");
        Serial.print(client.state());
        Serial.println(" try again in 5 seconds");
        // Wait 5 seconds before retrying
        delay(5000);
void loop(){
  WiFiClient(espClient) = server.available();   // Listen for incoming clients
  if (espClient) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (espClient.connected()) {            // loop while the client's connected
      if (espClient.available()) {             // if there's bytes to read from the client,
        char c = espClient.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
            break;
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    espClient.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
  if (!client.connected()) {
          reconnect();
  client.loop();
         //compute the required size
         const size_t CAPACITY = JSON_ARRAY_SIZE(5) + 5*JSON_OBJECT_SIZE(3);
         //allocate the memory for the document
         StaticJsonDocument<CAPACITY> doc;
        //Create an empty array
        JsonArray arr = doc.to<JsonArray>();
        //definiamo quanti campioni registrare prima di inviarli tramite mqtt
        for (int i=0; i<5; i++){
            //MPU reading
            Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
            Wire.endTransmission(false);
            Wire.requestFrom(MPU, 14, true); // request a total of 14 registers
            AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
            AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
            AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
            //Create JSON Array
            JsonObject obj = doc.createNestedObject();
            obj["AcX"] = AcX;
            obj["AcY"] = AcY;
            obj["AcZ"] = AcZ;
            delay(3000);
       //MQTT PUBLISHING JSON PACKAGE
       char mqttData[MQTT_BUFFER];
       serializeJson(doc, mqttData);
       Serial.println(mqttData);
       client.publish("esp8266", mqttData);
       //client.subscribe("esp8266");
       delay(10000);
      //Inserire un ciclo WHILE dove
      //mentre il wifi è connesso invia i dati all'mqtt
      //altrimenti li salva e basta
Try changing
to the IP address of the pi which, I assume (dangerous I know) is where the MQTT broker is running.
Sorted on Stack Overflow
