I seem to be having issues updating a node (Blocky) on my Win10 machine so I'd like to nuke it from orbit and start again
What to I need to do to remove it?
Simply delete c:\users\Simon.node-red folder ? (having made copies of my existing flows 1st of course)
Simon
Slightly less drastic (to start with). Check if you have a package.json in your .node-red dir. if so then edit it manually to remove blocky. Then delete the node_modules directory. Then run npm i to reinstall any other modules. And then restart Node-RED.
If that fails then yes. Go for the big delete.
npm i and big delete made no diff
Turns out to be some sort of wierd browser issue
I normally use Vivaldi to edit my flows and its showing up old version of the Blockly node
But when I tried viewing it in Chrome - it shows the latest version
Very weird
I just went into Vivaldi settings and completely cleared all history/cache - did a shift-F5 just for luck and now its fine in Vivaldi as well
