Working between Floating Point and Int. data types
It's perfect!! Right on the money. Scale head is reporting 15765 and debug:
Thanks again
I am not sure you need to the function node at all. As an experiment replace the function node I posted with a Change node configured as below, basically it just moves the buffer into the payload and passes it on the conversion function. The conversion function will accept a buffer, though I haven't checked the bytes are in the right order. If it doesn't work then go back to the function node.
This seems to give me:
from the IEEE-754 to float function.
OK, I see what is happening and it needs a function to fix it, so best to stick with the one that works.
