Worldmap Node: Is there any way to change default bar icon?
Hello community,
Is there any way to change default Node-RED icon in the default Wordmap bar?
Could it be changed into some source code? If possible, can anyone point me the source file?
Many thanks in advace.
It is in the worldmap directory worlmap/images/node-red.png
Thank you so much @dceejay!
Created an icon with same size, uploaded to folder and showing ok :wink:
Don't forget this will get wiped if you upgrade the node - so backup your image and create a process for replacing it when upgrading.
