I installed worldmap but fail to diable user's UI. I can still do anything (as a user with this diabled)
Two things are worth checking. First, the user menu, map locking and zoom locking are three separate options in the worldmap node: hiding the User menu does not lock the map, so also set Lock map and Lock zoom if you want to stop panning and zooming. Second, the node only sends these settings to the browser when the map page connects (they are part of the init command in the node's code), so after changing them you need to deploy and then reload the map page itself - an already open page keeps the old settings. If it still misbehaves after a reload, that would look like a bug worth reporting on the RedMap GitHub issue tracker.
Thanks I'll try to recreate and recheck
Qill try to update it here
Also check you have latest version as I did add some fixes recently
