Would a subflow environment variable be able to set a password for a Database?
Let's say I take an InfluxDB In node in a subflow and configure it to some default settings based on how my stack is i.e.,
  • Database Address
  • Database Port
  • Default Database
  • Username
  • Password
Subflow
Subflow Environment Variables
Let the user have the ability to change the username / password / database via the Env Vars of the subflow
InfluxDB Configuration
Would I be able to resolve the password using $(password) in the dedicated Password field of the InfluxDB configuration?
I tried it out and it works.
The following:
will be able to obtain resolve the information from the Env Vars.
What one may not see is that the value of the Password is $(password).
Test flow
For the following flow where the function node is just
msg.query = "SHOW USERS";
The debug node is able to show values provided the user sets the password and username using the UI of the subflow
