XYD02 control panel and suggestions for improvement
Hi folks,
I've just created this control panel for the XY-MD02 RTU modbus sensor:
Today it's not much handy, as the user has to manually change the serial port reference in the modbus configuration node (se the GitHub readme).
Does anyone know a way to make this configuration possible from the dashboard itself? Or it's static in the configuration node and there is no way of dinamically change it?
BR
F
The modbus node that demo flow uses has a node called flex-connector
Modbus Flex Connector is a node for flexible input triggers to reconnect with new connection parameters.
The node has built in help and there might even be a built in demo (ctrl-i > examples)
Oookkk...that could be the solution I was looking for :grin:
I will definitely have a look tomorrow!
F.
@Steve-Mcl it works!
F.
