zane
19 December 2021 03:44
1
I am trying to map my family phones on a ui-worldmap.
I have them mapping ok. But I would like to change the zoom and location so they all fit in the screen.
I cant work out if this is possible.
I thought this would do it, but it seems to have no affect.
msg.payload.command = {};
msg.payload.command = {map: {
"fit": true,
"clickable": false
Not quite that simple but it can be done... you need to use a convex-hull node - this creates a shape that would hold all the points - and then make the shape itself invisible - and then fit the map to that.
(You will also need worldmap version 2.23.4
[{"id":"4b5f6be5.96c1f4","type":"worldmap-hull","z":"846d7832.3348c8","name":"","prop":"layer","x":520,"y":270,"wires":[["889b0e44.4fc8b","bc417f3349e3925a"]]},{"id":"bc417f3349e3925a","type":"function","z":"846d7832.3348c8","name":"","func":"msg.payload.fit = true;\nmsg.payload.fillOpacity = 0;\nmsg.payload.opacity = 0;\ndelete msg.payload.clickable;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":270,"wires":[["fd654fbf.7e7db"]]}]
zane
22 December 2021 02:34
3
that was perfect.. thank you!
