Are you using the speedtest node?
Can you try disabling it (under the manage pallet option and restart) and then retest please
Yes, that worked! Well done. I'll remove that node completely.
Copy the image to your clipboard and the simply paste it in
e.g
Let's see if it worked...
Thanks!
You need to copy the image itself to your clipboard- e.g do a screengrab
Or use the upload button (I've not tried it myself but it should work)
The copy/paste method worked BUT on Firefox (I don't know why I keep using the Brave Browser)
Same issues here with the http request node after upgrading to 2.0.1 (Docker). However, I do not have any Speedtest node installed...
How can I help to trace this?
I did the command suggested as above and got this:
Can you run the same command in /data to check the extra nodes you have installed?
We have a fix prepared for 2.0.2 that will undo the damage done by the old version of agent-base - at the possible cost of breaking the nodes that use the old version. On balance, that's a preferable way to approach it so we can more easily identify affected nodes and help get them updated.
Good news on my side!
After watching your video from today I installed everything again with "bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)" but this time including the nodejs 14 option.
Now the http request node works like a charm (texts are back, as they should)
Thanks a lot for your hard work!!!
Same problem here with multiple HTTP request nodes in use. I don't have speedtest installed.
RequestError: connect ECONNREFUSED 127.0.0.1:443
Looks like a DNS problem? Hostnames resolve to 127.0.0.1
Follow the instructions here, and then report back the results. Then, probably disable that node type.
node-red-docker@2.0.1 /usr/src/node-red
-- node-red@2.0.1 -- @node-red/nodes@2.0.1
-- https-proxy-agent@5.0.0 -- agent-base@6.0.2
Is this correct?
and also run it in /data directory.
bash-5.0$ pwd
/data
bash-5.0$ npm list agent-base
node-red-project@0.0.1 /data
`-- node-red-contrib-chatbot@0.19.7
+-- chat-platform@1.2.2
| `-- npm@6.14.8
| `-- npm-registry-fetch@4.0.7
| `-- make-fetch-happen@5.0.2
| +-- http-proxy-agent@2.1.0
| | `-- agent-base@4.3.0
| +-- https-proxy-agent@2.2.4
| | `-- agent-base@4.3.0 deduped
| `-- socks-proxy-agent@4.0.2
| `-- agent-base@4.2.1
+-- dialogflow@0.7.0
| `-- google-gax@0.20.0
| `-- google-auth-library@2.0.2
| `-- https-proxy-agent@2.2.4
+-- node-nlp@4.13.3
| `-- @nlpjs/request@4.13.2
| +-- http-proxy-agent@4.0.1
| | `-- agent-base@6.0.1
| `-- https-proxy-agent@5.0.0
`-- recastai@3.7.0
`-- superagent-proxy@1.0.3
`-- proxy-agent@2.3.1
+-- agent-base@4.3.0
+-- pac-proxy-agent@2.0.2
| +-- agent-base@4.3.0 deduped
| `-- http-proxy-agent@2.1.0
`-- socks-proxy-agent@3.0.1
