# IoTPlay Sprinkler System
## Introduction
A 4 x leg sprinkler system, and borehole pump switching system with RPi & Node-RED, and ESP8266
## Specifications of the System
Find below the requirements I had when building the flows.
#### Functional:
- 4 sprinkler leg valves to be switched on- and off.
- A borehole pump to be switched on before any leg is activated, and switched off afterwards.
#### Schedules:
- On the sprinkler `leg schedules`:
- Able to switch each leg on `twice a day`;
- Able to choose which legs should sprinkle on `which days`;
- `Duration between` legs on as a variable- to allow the borehole water to fill-up;
This file has been truncated. show original
