403 error while installing NPM
I am getting an error when installing NPM .I am a novice and hence need a little hand holding. Please find the list of commands and the error as given below.
C:\Windows\system32>node --version
v16.17.0
C:\Windows\system32>npm --version
8.19.1
C:\Windows\system32>npm install -g -unsafe.perm node.red
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/node.red - Not found
npm ERR! 404
npm ERR! 404 'node.red@*' is not in this registry.
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! C:\Users\jokahelpdesk\AppData\Local\npm-cache_logs\2022-09-06T05_35_45_367Z-debug-0.log
Please help!
Check the command you are typing. -unsafe.perm is incorrect
ok so , how do i install node red after installing node.js?
What should be the command?
See Running on Windows : Node-RED
Everything you need to know should be there.
Also, the package you want to install is node-red not node.red
Thanks a lot..Followed the instructions and getting the results as given below:
C:\Windows\system32> npm install -g --unsafe-perm node-red
added 292 packages, and audited 293 packages in 42s
38 packages are looking for funding
run npm fund for details
5 vulnerabilities (4 low, 1 moderate)
To address issues that do not require attention, run:
npm audit fix
To address all issues (including breaking changes), run:
npm audit fix --force
Run npm audit for details.
...Probably the installation is not complete..!
It is complete.
Close and reopen your terminal & run node-red
Thanks everyone, its working!!
