Raspberry NPM Node Red install error
running the install script for raspbery (bash curl ...) on raspberry 3b raspbian buster with node version 12.8.3 and npm Version 6.14.6 finishes with no errors (all green), but i do get error starting node-red-start indicating node-red is not fully installed.
It seems that current node red is not fully found in npm! I cant post full install log due to fforum restrictions regarding links, but here is the error part:
Now install Node-RED
npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/@node-red%2Feditor-api - Not found
npm ERR! 404
npm ERR! 404 '@node-red/editor-api@1.1.3' is not in the npm registry.
npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
npm ERR! 404 It was specified as a dependency of 'node-red'
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! /root/.npm/_logs/2020-08-06T09_59_38_791Z-debug.log
Now create basic package.json for the user and move any global nodes
https://status.npmjs.org/incidents/cksjqc1w11v5
oh thx! I wasn't aware that the problem lies with npm itself.
If you wait till the error in the link is fixed and then run the script again it should be ok.
