A Strange Anomaly With Column Widths Dashboard 2.0
I have noticed that column widths are not all the same on a page. See image below. The Group of 4 columns has wider columns than the Group having 2 columns. Does anyone have an answer as to why this is and is there a way to get round the issue?
Note: As one would expect the columns do get proportionally wider if the Browser window width is increased
Dashboard 2 v1.28
MS Edge
Default Theme
Widgets are ui-template nodes with a CSS width of 70px for button
Can you export and paste here one widget from each group please?
Also, check the open issues on the dashboard's GitHub page, I seem to remember something about ui-template's width.
The widgets are all the same
<template>
    <v-card class = "card">
        <v-btn class = "btnBasic" :class = "btnClass" stacked @click="changeState()">
            {{btnLabel}}
            <v-icon class = "iconBasic" :class = "iconClass" >{{iconImage}}</v-icon>
        </v-btn>
    </v-card>
</template>
<script>
    export default {
        data() {
            return {
                source: 'Dashboard',
                systemData: {button: {applianceName: 'Kitchen Air Fryer',
                                      systemAttributeID: 'OnOff'},
                // Note that when btnState = 0 the button will always be shown as 'Off'
                btnState: 0,
				btnData: {class: ['btnOff', 'btnOn'],
                          label: ['SO']
                iconData: {class: ['iconOff', 'iconOn'],
                           image: ['mdi-power-socket-uk']
                outputValue:  ['Off', 'On'],
        methods: {
            changeState: function () {
				this.toggleState(this.btnState)
				let topic = `${this.source}/${this.systemData.button.applianceName}/${this.systemData.button.systemAttributeID}`
                this.send( {topic, payload: this.outputValue[this.btnState]} )
            toggleState: function () {
                this.btnState = (++this.btnState) % this.outputValue.length
            validateOption: function(option) {
                const optionMax = option.length - 1
                let optionSelect = this.btnState
                if (optionSelect > optionMax) {
                    optionSelect = optionMax
                return option[optionSelect]
            /** Update Widget property values if required
            * Input    ui-update
            *          label                Array of string, length 1 or more. Only number of outputValues
            *                               will be shown. Note: The first entry in the Array will match the first
            *                                entry in 'output'
            *          output               Array of output values (any), length 1 or more. Each 'click' of
            *                               button will output next value in Array. Button label will also
            *                               update for each 'click' if there is more than 1 element in btnData.label
            *                               Array
            *          icon                 New mdi icon
            setDynamicUpdates(uiUpdates) {
                for (const [property, value] of Object.entries(uiUpdates)) {
                    if (Array.isArray(value)) {
                        if (property === 'label') {
                            this.btnData.label = value
                        if (property === 'output') {
                            this.outputValue = value
                    if (property === 'icon') {
                        this.iconData.image = value
        watch:  {
            msg: function () {
                    const [protocol, applianceName, deviceName, attribute, action = ''] = this.msg.topic.split('/')
                    const btnApplianceName = this.systemData.button.applianceName
                    if (btnApplianceName === applianceName) {
                        const payloadValue = this.msg.payload?.value
                        if (attribute === 'OnOff') {
                            // Only change btnState if msg.payload is valid (i.e. is found in outputValue)
                            if (this.outputValue.indexOf(payloadValue) !== -1) {
                                this.btnState = this.outputValue.indexOf(payloadValue)
        computed: {
            // Automatically compute these variables whenever VueJS deems appropriate
            btnLabel: function() {
                return this.validateOption(this.btnData.label)
            btnClass: function() {
                return this.validateOption(this.btnData.class)
            iconClass: function() {
                return this.validateOption(this.iconData.class)
            iconImage: function() {
                return this.validateOption(this.iconData.image)
        mounted () {
            this.$socket.on("msg-input:" + this.id, (msg) => {
                 * Comply with Dashboard 2 schema to set dynamic values
                 * msg:     ui-update: {<property>: value}
                if ( Object.hasOwn(msg, 'ui_update') ) {
                    this.setDynamicUpdates(msg.ui_update)
        unmounted() {
            // code here when the component is removed from the Dashboard
            // i.e. when the user navigates away from the page
            this.$socket.off(`msg-input:${this.id}`)
</script>
<style scoped>
</style>
CSS ui-template node
    .card {
        background-color: #4F4F4F;                          /* Very dark gray */
        border: 1px solid black;
        border-radius: 8px;
        width: 75px !important;
        height: 105px;
    .btnBasic {
        border-radius: 8px;
        width: 70px !important;
        height: 75px !important;
	.btnOn {
        color: rgb(189, 150, 8);                            /* Dark washed rose */
	.btnOff {
		color: darkgrey;
	.iconBasic {
		font-size: 45px;
        height: 45px;
        width: 45px;
	.iconOn {
        text-shadow: rgb(189, 150, 8) 0px 0px 10px;         /* Dark washed rose */
	.iconOff {
		color: darkgrey;
		text-shadow: 0px 0px 0px;
    .v-slider-thumb__surface{
        background-color: currentColor;
The ui-template nodes are all the same width, (as checked with the browser developer tools) it is the columns that vary
Please supply the export as requested. That will include all the group page and theme settings so we can see if we see the same issue. Also include any relevant css templates you have
It's OK, I see what you mean. There seems to be a fundamental error in the maths somewhere. This example with four buttons (1x1) across a group that is four wide, and two buttons across a group that is two wide shows the problem.
It can be seen that the buttons in the two groups are not the same size. I suspect the problem is that in the 4x1 group there are four buttons and and 5 gaps (including the edges), whereas in the 2x1 group there are two buttons and three gaps. I think the border at the edges should only be half the width of the inter-button borders, then there would be a total of four gaps and two gaps respectively, so they will fit correctly into a group that is half the width.
I have raised an issue for this Widget size varies with group width · Issue #1891 · FlowFuse/node-red-dashboard · GitHub
Thank you
Re-opened just to note that, in the issue linked above, it has been decided not to change the code to make the widget widths uniform, as that would slightly change the appearance of existing dashboards, which could be annoying to many users. Instead the docs have been updated to describe how to use the theme and CSS to adjust the widths accordingly. To quote from the help text from the next dashboard release:
### Making widget widths uniform
A group insets its widgets with a small side padding, and because that padding is shared across the group's columns, a 1×1 widget is a touch narrower in a narrow group than in a wide one. To make widths match across all group sizes, set that padding equal to `(Widget Gap − Group Gap) / 2` using a [`ui-template`](../../nodes/widgets/ui-template.md) CSS override.
For example, with the default 12px gaps, set **Group Gap** to `0` and add:
.nrdb-ui-group .v-card-text {
  padding: 6px;
Here is the test flow from the issue, with the adjusted theme and CSS override applied.
[{"id":"47069383b4f76581","type":"ui-template","z":"997da33a0beedade","group":"","page":"","ui":"ID-BASE-1","name":"Adjust spacing for equal widget widths","order":0,"width":0,"height":0,"head":"","format":".nrdb-ui-group .v-card-text {\n    padding: 6px;\n}","storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"site:style","className":"","x":270,"y":6920,"wires":[[]]},{"id":"708fb2e61d38b271","type":"group","z":"997da33a0beedade","name":"Button Width Test","style":{"label":true},"nodes":["bafbd196632d4d9f","4698f660c113e1f3","8fdb7f4e8a8cc6c5","9e35f17b19b7fd0b","adbfdc33663e1abb","82272e556a61cd32","eb3f9d0e95d20745","e7e9e4875d859fb1"],"x":94,"y":6739,"w":832,"h":142},{"id":"bafbd196632d4d9f","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":5,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":170,"y":6780,"wires":[[]]},{"id":"4698f660c113e1f3","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":4,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":610,"y":6780,"wires":[[]]},{"id":"8fdb7f4e8a8cc6c5","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":2,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":470,"y":6780,"wires":[[]]},{"id":"9e35f17b19b7fd0b","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":1,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":330,"y":6780,"wires":[[]]},{"id":"adbfdc33663e1abb","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":6,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":730,"y":6780,"wires":[[]]},{"id":"82272e556a61cd32","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f61ab9f04574e6e5","name":"","label":"button","order":1,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":170,"y":6840,"wires":[[]]},{"id":"eb3f9d0e95d20745","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f4cd34922b93a93a","name":"","label":"button","order":3,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":850,"y":6780,"wires":[[]]},{"id":"e7e9e4875d859fb1","type":"ui-button","z":"997da33a0beedade","g":"708fb2e61d38b271","group":"f61ab9f04574e6e5","name":"","label":"button","order":2,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":330,"y":6840,"wires":[[]]},{"id":"f4cd34922b93a93a","type":"ui-group","name":"6x1","page":"94740f3451825304","width":"6","height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"f61ab9f04574e6e5","type":"ui-group","name":"2x1","page":"94740f3451825304","width":"2","height":1,"order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"94740f3451825304","type":"ui-page","name":"group width test","ui":"ID-BASE-1","path":"/group_width","icon":"home","layout":"grid","theme":"4c44f59af1869a6e","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":"true","disabled":"false"},{"id":"4c44f59af1869a6e","type":"ui-theme","name":"Equal widgets theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"0px","groupBorderRadius":"4px","widgetGap":"12px"}},{"id":"ID-BASE-1","type":"ui-base","name":"Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-control","ui-notification"],"showPathInSidebar":false,"headerContent":"page","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":"1","showDisconnectNotification":true,"allowInstall":true},{"id":"5a1af960470ee01f","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.30.2"}}]
Cheers Colin, however
As you can see the left margin is a lot less than the right. The reason is that the button widget is only 90% wide. I had to add a 6px to the left margin to get them centred (I couldn't work out how to centre the widgets using justify* but there must be a way). I have included the template & css code just in case it helps.
<template>
    <v-card class = "btn-container">
        <v-btn class = "btn with-slider" :class = "btnClass" stacked @click="changeState()">
            {{btnLabel}}
            <v-icon class = "icon basic" :class = "iconClass" >{{iconImage}}</v-icon>
        </v-btn>
        <v-slider
            v-model = "sliderValue"
            width = "80%"
            :min = "sliderRange.min"
            :max = "sliderRange.max"
            thumb-size = "12"
            :color = "sliderColour"
            @end = "updateSlider()">
        </v-slider>
    </v-card>
</template>
/* New CSS - now updated                                                        */
.btn-container {
    border-radius: 8px;
    width: 90%;
    height: 100%;
    margin-inline-start: 6px;                           /* Added to centre widget */
.btn {
    &.basic {
        border-radius: 8px;
        width: 100%;
        height: 90%;
    &.with-slider {
        border-radius: 8px;
        width: 100% !important;
        height: 70% !important;
	&.on {
	&.off {
		color: darkgrey;
.icon {
    &.basic {
		font-size: 45px;
        height: 45px;
         width: 45px;
	&.on {
	&.off {
		color: darkgrey;
  padding: 6px;
After
