Hi all
I'm working with Node-Red version v0.18.1 on Raspian version 9.
I would to know if there is a way to know if a file exist ad put the result in a Switch.
thanks in advance
Hi all
thanks in advance
There are some filing system nodes around, check the flows site. Otherwise you can add a reference to the fs node library to the globals section in settings.js and then use global.get in a function. You can then use fs inside the function and just use the node.js functions.
I'm particular...
fs-ops-access - Test existence and accessibility of a file or directory
