Bonjour
i want to know if a file exist on my application.
For my test i use fs-ops-access and it is ok if the parameter Filename is unchangeable.
But for my application i want to change dynamically the Filename property.
Can you help me ?
my node
"id": "df863d4.60fed4",
"type": "tab",
"label": "Flow 7",
"disabled": false,
"info": ""
"id": "27170ae.b550176",
"type": "fs-ops-access",
"z": "df863d4.60fed4",
"path": "Documents/Datas",
"pathType": "str",
"filename": "filecsv.cs",
"filenameType": "str",
"read": true,
"write": true,
"throwerror": true,
"x": 700,
"y": 420,
"39b43f98.6b1c8"
"3c84cbdc.0cf004"
"id": "ff561338.be1528",
"type": "inject",
"topic": "",
"payload": "",
"payloadType": "date",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 320,
"y": 420,
"a18cc6af.01003"
"id": "39b43f98.6b1c8",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 880,
"y": 380,
"wires":
"id": "3c84cbdc.0cf004",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 870,
"y": 460,
"wires":
"id": "a18cc6af.01003",
"type": "function",
"func": "msg={Filename :"filecsv.csv"};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 490,
"y": 420,
"27170ae.b550176",
"cc12c5d4.1ccb08"
"id": "cc12c5d4.1ccb08",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 700,
"y": 600,
"wires":
