A working node, suddenly is claiming "Invalid Properties" - confignode. Yet I haven't changed it
Trying to figure out how to track down exactly what is the issue with one of my pallets. Seems it now has the little red triangle on top of every node, claiming "invalid properties: - confignode"
When I open the node, It has one of the config objects in RED, when I click the pencil. The object looks fine.
In addition, I can make configuration changes, commit those changes, and everything functions fine. Only annoying thing is that of course, every time I commit I get a screen of warning for all my nodes effected saying "The workspace contains some nodes that are not properly configured" I've looked at the config node, and the only object that has a "required" or "validated" tag on it is the name object, and it is definitely not null, or an empty string. It's a valid name.
The original node was node-red-contrib-lutron v1.0.3. But I modified it months ago to allow for queries, and to handle the Pico node, which is different from a Shade. But, like I say, it was working fine up until today while I was duplicating one of the other non related nodes.
Nodejs version: 12.22.10
node- red version: V2.2.2
npm version: 6.14.16
Here are some screen shots, any suggestions would be greatly appreciated.
lutron-screenshot
lutron-statusnode-config
and a copy of the lutron-config.html file.
    RED.nodes.registerType('lutron-config', {
        category: 'config',
        defaults: {
                value: ""
                required: true
            ipaddress: {
                value: ""
            deviceMap: {
                "ALL": 0
            deviceType: {
                "ALL": 0
            timeout: {
                value: 45000
            controlnode: { value: "", type: "lutron-control" }
        label: function () {
            return this.name;
        oneditprepare: function () {
            var key = '';
            var tableContent = '<table class="table"> <tr><th>Name</th><th>Device ID</th><th>Device Type</th><th></th>';
            tableContent += '<th></th><span id="lutron-table-add" class="lutron-table-add fa fa-plus"></span></tr>';
            var deviceMap = this.deviceMap || this._def.defaults.deviceMap;
            var deviceType = this.deviceType || this._def.defaults.deviceType;
            for (key in deviceMap) {
                tableContent += '<tr>';
                tableContent += '<td contenteditable="true">' + key + '</td>';
                tableContent += '<td contenteditable="true">' + deviceMap[key] + '</td>';
                tableContent += '<td contenteditable="true">' + deviceType[key] + '</td>';
                tableContent += '<td> <span class="lutron-table-remove fa fa-times"></span> </td>'
                tableContent += '</tr>';
            // add one hidden entry for adding rows
            tableContent += '<tr class="hide">'
            tableContent += '<td contenteditable="true">Add Name</td>'
            tableContent += '<td contenteditable="true">0</td>'
            tableContent += '</tr></table>';
            $('#lutron-table').html(tableContent);
            var $TABLE = $('#lutron-table');
            var $BTNADD = $('#lutron-table-add');
            $BTNADD.click(function () {
                var $clone = $TABLE.find('tr.hide').clone(true).removeClass('hide table-line');
                $TABLE.find('table').append($clone);
            $('.lutron-table-remove').click(function () {
                $(this).parents('tr').detach();
            // A few jQuery helpers for exporting only
            jQuery.fn.pop = [].pop;
            jQuery.fn.shift = [].shift;
        oneditsave: function () {
            var $rows = $TABLE.find('tr:not(:hidden)');
            var headers = [];
            var data = {};
            var types = {};
            // Get the headers (add special header logic here)
            // Shift off first row from $rows.
            $($rows.shift()).find('th:not(:empty)').each(function () {
                headers.push($(this).text().toLowerCase()); // Stuff the header name onto array headers.
            // Turn all existing rows into a loopable array
            // Loop through remaining rows
            $rows.each(function () {
                var $td = $(this).find('td'); // Pull all the td's from this row into an array
                var h = {};
                // Use the headers from earlier to name our hash keys
                headers.forEach(function (header, i) { // foreach element in the headers array.
                    h[header] = $td.eq(i).text(); // copy the header text info object h.[header]
                data[h['name']] = h['device id'];
                types[h['name']] = h['device type'];
            this.deviceMap = data;
            this.deviceType = types;
</script>
<script type="text/x-red" data-template-name="lutron-config">
    <div class="form-row">
        <label for="node-config-input-name"><i class="fa fa-tag"></i> Name</label>
        <input type="text" id="node-config-input-name" placeholder="Name"></input>
    </div>
    <div><p></p></div>
        <label for="node-config-input-ipaddress"><i class="fa fa-globe"></i> IP Address</label>
        <input type="text" id="node-config-input-ipaddress" placeholder="192.168.xx.xx"></input>
    </div>
        <label for="node-config-input-timeout"><i class="fa fa-globe"></i> Timeout (ms)</label>
        <input type="text" id="node-config-input-timeout" placeholder="30000"></input>
    </div>
   <!--      Table Class -->
   <h2 style="color:brown; margin-left:490px;margin-top:0px;">Device mapping table</h2>
   <div class="container">
            <div id="lutron-table" class="lutron-table-editable">
            </div>
        </div>
    <style>
            .lutron-table-editable {
                position: relative;
                .glyphicon {
                  font-size: 20px;
              .lutron-table-remove {
                color: #700;
                cursor: pointer;
                &:hover {
                  color: #f00;
              .lutron-table-add {
                color: #070;
                cursor: pointer;
                position: absolute;
                top: 8px;
                right: 0;
                &:hover {
                  color: #0b0;
    </style>
</script>
Correction to the code pasted above. Even though the copy I pasted here doesn't have a "," after value: ""
That comma is actually there. I just cut and pasted the code having removed the comma, briefly when I removed required: true but failed to put it back in before I cut and pasted it into this post.
