Node-RED 1.3.0: The workspace contains some nodes that are not properly configured
since the update to 1.3.0 I am getting the error "The workspace contains some nodes that are not properly configured" when I try to deploy...
But I haven't changed anything on the change function:
Any ideas?
Thanks!
I'm having the same issue with the 'change' nodes... I installed it on my MacBook Pro (which already had v1.3 beta) and a Windows server (which was v1.2.9) and I am having the same issue with both???
@dudleyjosh and @jo_strasser
could you highlight and export (CTRL+E) a couple of these problem nodes?
[{"id":"ae1d9d5e.a26c3","type":"change","z":"74f73e0c.f8cdb","name":"CONFIG","rules":[{"t":"set","p":"flowfile","pt":"flow","to":"mfg","tot":"str"},{"t":"set","p":"hostname","pt":"flow","to":"LCWWWSrv-2012","tot":"str"},{"t":"set","p":"flowDir","pt":"flow","to":"C:\\Users\\administrator.ABRASIVE-TECH\\.node-red\\projects\\NR-mfg","tot":"str"},{"t":"set","p":"backupDir","pt":"flow","to":"C:\\Users\\administrator.ABRASIVE-TECH\\.node-red\\backup\\","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":40,"wires":[[]]}]
[{"id":"a7f00964.a02138","type":"change","z":"6e623998.59b148","name":"host & port","rules":[{"t":"set","p":"host","pt":"msg","to":"10.1.11.152","tot":"str"},{"t":"set","p":"port","pt":"msg","to":"8500","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":140,"wires":[["5a203ef9.ce88"]]}]
[{"id":"b2fab3d0.3db57","type":"change","z":"eb15b919.fc806","name":"Prepare Data","rules":[{"t":"set","p":"measurement","pt":"msg","to":"topic","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":560,"wires":[["94f08ac0.fc58a8"]]}]
me too:
[{"id":"7d1d3a81.7245f4","type":"change","z":"54aa6e3f.bae55","g":"266cdd98.59aba2","name":"set icon","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"<i class=\"fa fa-circle\"></i>","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"<i class=\"fa fa-circle-o\"></i>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":160,"wires":[["d852647.eafcc98"]]}]
Sorry all - my bad.
Fix pushed to git - 1.3.1 will be released shortly.
No prob, thanks!
1.3.1 now published.
No problem and many thanks! :slight_smile:
