Hello
Is it possible to abort a flow during the run in a function with a certain If Then condition so that no payloads or other things are output? The function should then behave absolutely calmly as if nothing had happened.
I have only found the possibility that the function has 2 outputs and I let the second output run into nothing with the If Then condition.
If you are in a Function node then return null will not send a message. A common pattern that I use is
if (some condition) {
msg = null
} else {
do normal stuff
return msg
THX
that makes live easy
If you are not already in a function node then you can use a Switch node that checks the state and only passes good messages through. So for example is you only wanted messages where the payload is 1 then configure it like
Any other messages will be dropped.
