About node-red-contrib-sftpco
When reading a file using the Get method
It will be read as UTF-8.
Is there no way to change the character code?
Also, enter the host, username and password on this node.
Is it possible to pass it as a variable?
Thank you.
Welcome to the forums @Node7189
Sadly, no... it is not possible, you will need to raise the request with the author of the node.
Support is there in the upstream library, but node-red-contrib-sftpco does not expose it
Thank you for answering.
I'm sorry.
I would like to consider other nodes.
When using GET method with node-red-contrib-sftp
Where will the files be saved?
I will continue to research on my own, but if you know
Please lend me your wisdom.
We apologize for any inconvenience this may cause, and appreciate your understanding.
Sorry - I don't use any file transfer in Node RED.
If someone here uses the nodes, they may answer, if not, its best to review documentation.
Colin
21 December 2023 13:52
6
I never got success using ftp nodes, so now when I need it I just use exec nodes to run the commands I need.
Thank you for sharing the document. I would like to investigate.
