I have installed xampp as a file server.
I used the List method of SFTP node to see the file and directory information at Remote Path:
In the Method list of this node, there are many other methods such as Get, Put, ...
I have investigated and tried config but don't work:
[{"id":"e9c2550a.80a8c8","type":"tab","label":"Get/Put using SFTP","disabled":false,"info":""},{"id":"f3f32b35.475718","type":"inject","z":"e9c2550a.80a8c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":190,"y":180,"wires":[["f14e96bb.8d2bc8"]]},{"id":"5f02d6d6.973f98","type":"debug","z":"e9c2550a.80a8c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":870,"y":180,"wires":[]},{"id":"f14e96bb.8d2bc8","type":"SFTP-main","z":"e9c2550a.80a8c8","path":"/","method":"get","remoteFilePath":"/xampp/htdocs/applications.html","localFilePath":"/Temp/AAA","remoteDestPath":"/","useCompression":"","encoding":"utf8","mode":"","recursive":"false","server":"e800b82d.2c5468","x":350,"y":180,"wires":[["4f38a4ba.ba46cc","153e0b73.d3bcb5"]]},{"id":"e372849a.99b548","type":"file","z":"e9c2550a.80a8c8","name":"","filename":"","appendNewline":true,"createDir":true,"overwriteFile":"true","encoding":"none","x":730,"y":180,"wires":[["5f02d6d6.973f98"]]},{"id":"4f38a4ba.ba46cc","type":"debug","z":"e9c2550a.80a8c8","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":480,"y":120,"wires":[]},{"id":"153e0b73.d3bcb5","type":"change","z":"e9c2550a.80a8c8","name":"","rules":[{"t":"set","p":"filename","pt":"msg","to":"payload.path","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":180,"wires":[["e372849a.99b548","6fa51884.744708"]]},{"id":"3b6af2c3.9d751e","type":"comment","z":"e9c2550a.80a8c8","name":"Get","info":"","x":350,"y":140,"wires":[]},{"id":"6fa51884.744708","type":"debug","z":"e9c2550a.80a8c8","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":720,"y":120,"wires":[]},{"id":"6986aa7b.294dd4","type":"inject","z":"e9c2550a.80a8c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":190,"y":360,"wires":[["298c8460.34decc"]]},{"id":"298c8460.34decc","type":"SFTP-main","z":"e9c2550a.80a8c8","path":"/","method":"put","remoteFilePath":"/xampp/htdocs/","localFilePath":"/Temp/Data/","remoteDestPath":"/","useCompression":"","encoding":"utf8","mode":"","recursive":"false","server":"e800b82d.2c5468","x":350,"y":360,"wires":[["b0a18be1.a66a08"]]},{"id":"b0a18be1.a66a08","type":"debug","z":"e9c2550a.80a8c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":510,"y":360,"wires":[]},{"id":"65c833f.dd23ecc","type":"comment","z":"e9c2550a.80a8c8","name":"Put","info":"","x":350,"y":320,"wires":[]},{"id":"e800b82d.2c5468","type":"SFTP-credentials","z":"","host":"127.0.0.1","port":"22","username":"admin","password":"20160605"}]
If you know how to use Get, Put method of this node please let me know.
Thanks!
