Hello, I have an HTLM node that gets a binary file as a repsonse. The file is located in something like:
/data/folder/file.mp3
Is there a way to get access to that file from outside nodered? (same network) With http request for example. Something like:
http://nodered_ip/data/file.mp3
That does not work by the way.
Thanks in advance
You can use http endpoints to server file Serve a local file : Node-RED. You then make a http request to the endpoint, the endpoint flow can then make a http request to get your file and return it with the http response node.
[edit] You can also server files from a http static folder Configuration : Node-RED.
Will give that a try. Thank you
