Add linefeed to begin of string
I have a display connected to a serial line. That display clears its screen if it receives a linefeed. (I wrote the code myself, it is a ATTiny2313 with a 2x16 LCD screen attached and a RS232 driver/reciever chip and 4 buttons)
I want to display some information on it but I need to clear the screen in advance.
So my question is: how to put a \n in front of a string? (msg.payload)
I searched and found something with JSONata but could not make it to work.
template node to add a prefix and then \n?
So it would be (in the template node):
\n{{msg.payload}}
May work.
Should do.
Alternatively, a function node...
msg.payload = '\n' + msg.payload;
I'm certain a JSONata version is possible too.
Edit - thoughts and musings....
I know JSONata is an order of magnitude times slower than the function node (I've posted about this before so I mostly avoid JSONata - but in this simple example, the difference will be negligible) however, I've never done a speed test between a function node and template node.
My thoughts are the mustache will be comparable to JSONata ? :thinking:
