Hi All
Im deeply frustrated with this.
I'm trying to send text to a nextion display using serial.
Inject node fires a function with this code
msg.payload = 't0.txt="' + msg.payload + '"';
But alas this does not appear. I have tried everything and it should just work. Here's my outgoing msg.payload from debugNode
t0.txt="Please"
I have a textbox in the HMI called t0
Thanks in advance
Rob
Isn't it that al commands that are send to the display have to be terminated with 3x 0xff?
msg.payload = "t0.txt=" + msg.payload + "\xFF\xFF\xFF" ;
Sorry, don't have Nextion display anymore to test.
I thought the same but could not get it to work.
Thanks for trying
Rob
Also don't forget that the serial out node may add a closing line-feed character as well, you might need to play with the settings.
