Nodered Nextion Display
iam new and i would like to use Nodered + Nextion HMI.
I have a serial connection and can use buttons as well.
To get data ist not the problem.
I want to send a txt to a t0.txt part.
But till now i tried a lot, look in this forum and try to help myself.
It is useless. I need help.
I do not see any symstem working fine, by sending informations to the nextion.
Do anybody have any idea?
Found this:
(Syntax command control nextion display)
But i do not use MQTT.
Alex
Have you tried a simple inject node to send a string like NEXTION,t0.txt="hello" to the serial node?
thanks for your help.
Yes, the debug:
But i cannot see anything on that HMI
Could it be, that the Nextion want to get a buffer for input?
Thanks alex
the serial node sorts that out automatically.
It could be you need to append a linefeed or carriage return (or both)
try adding them see what happens.
NOTE: to add a \r CR you can use the inject node but a function node is just as easy...
hello,
i´d tried
this is the funtion
but nothing change in the HMI
Alex
Did you made a t0 element on your Nextion display with the Nextion editor?
Looks like it
@holographic Perhaps post your flow and HMI file so anyone with a Nextion can test if need be.
Yes i do.
I cannat upload a tft file here. Look like that is blocked.
Upload from the nodes
EDIT:
        "id": "9f2e75f318e0db1f",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": ""
        "id": "f439f64620f88998",
        "type": "serial in",
        "z": "9f2e75f318e0db1f",
        "name": "Nextion",
        "serial": "f527860f.a985e8",
        "x": 790,
        "y": 380,
                "f2259c6fbec866b1",
                "4deff35a28f1ce03"
        "id": "94a2dac7d9f23039",
        "type": "serial out",
        "name": "NEXTION",
        "x": 2500,
        "y": 100,
        "id": "0c779c63ceee7d51",
        "type": "switch",
        "name": "Which Button",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "2",
                "vt": "str"
                "t": "eq",
                "v": "5",
                "vt": "str"
                "t": "eq",
                "v": "6",
                "vt": "str"
                "t": "eq",
                "v": "9",
                "vt": "str"
        "checkall": "false",
        "repair": false,
        "outputs": 4,
        "x": 1380,
        "y": 380,
                "45470bcfb022c93a"
                "ee791fc6b48d9a70",
                "c7dae7fc1337a474"
                "842caeb9f13ca686",
                "3c462d2a75019956"
        "outputLabels": [
            "Licht Links",
            "Licht Rechts",
            "Drucker Links",
        "id": "842caeb9f13ca686",
        "type": "debug",
        "name": "2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 2330,
        "y": 360,
        "id": "e142724742466dbd",
        "type": "rpi-gpio out",
        "name": "PIN7",
        "pin": "7",
        "set": false,
        "level": "1",
        "freq": "",
        "out": "out",
        "x": 2330,
        "y": 200,
        "id": "772b8447c8b8a17f",
        "name": "Gewindemodus",
        "pin": "11",
        "set": "",
        "level": "0",
        "freq": "",
        "out": "out",
        "x": 2360,
        "y": 400,
        "id": "e4489f852968afae",
        "type": "comment",
        "name": "Lampe ein",
        "info": "",
        "x": 2500,
        "y": 200,
        "id": "ee791fc6b48d9a70",
        "type": "debug",
        "name": "8",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2330,
        "y": 260,
        "id": "778f5ff619e9f46b",
        "name": "Maschine an",
        "pin": "37",
        "set": "",
        "level": "0",
        "freq": "",
        "out": "out",
        "x": 2350,
        "y": 300,
        "id": "f7bd3ed22b4a5c0d",
        "type": "comment",
        "name": "Maschine AN",
        "info": "nur ein Test",
        "x": 2530,
        "y": 300,
        "id": "3afaec171c8666dd",
        "type": "inject",
        "name": "shutdown!",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "",
        "topic": "",
        "payloadType": "date",
        "x": 1120,
        "y": 760,
                "ee6f6a6a85ee79a9"
        "id": "ee6f6a6a85ee79a9",
        "type": "exec",
        "command": "sudo shutdown -h 0 #",
        "addpay": "",
        "append": "",
        "useSpawn": "",
        "timer": "",
        "winHide": false,
        "name": "turn off Pi",
        "x": 1300,
        "y": 760,
        "id": "3c0bbdb2ddb1129f",
        "type": "inject",
        "name": "neustart!",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "",
        "topic": "",
        "x": 1120,
        "y": 840,
                "311ec29c7d00d7ab"
        "id": "311ec29c7d00d7ab",
        "type": "exec",
        "command": "sudo shutdown -r 0 #",
        "addpay": "",
        "append": "",
        "useSpawn": "",
        "timer": "",
        "winHide": false,
        "x": 1300,
        "y": 840,
        "id": "45470bcfb022c93a",
        "type": "toggle",
        "onOffTopic": "",
        "onValue": "1",
        "onType": "str",
        "offValue": "0",
        "offType": "str",
        "toggleTopic": "",
        "toggleValue": "2",
        "toggleType": "str",
        "passOnOff": "",
        "x": 2170,
        "y": 220,
                "e142724742466dbd"
        "id": "c7dae7fc1337a474",
        "type": "toggle",
        "onOffTopic": "",
        "onValue": "1",
        "onType": "str",
        "offValue": "0",
        "offType": "str",
        "toggleTopic": "",
        "toggleValue": "5",
        "passOnOff": "",
        "x": 2170,
        "y": 320,
                "778f5ff619e9f46b"
        "id": "3c462d2a75019956",
        "type": "toggle",
        "onOffTopic": "",
        "onValue": "1",
        "onType": "str",
        "offValue": "0",
        "offType": "str",
        "toggleTopic": "",
        "toggleValue": "6",
        "passOnOff": "",
        "x": 2170,
        "y": 400,
                "772b8447c8b8a17f"
        "id": "f2259c6fbec866b1",
        "type": "function",
        "name": "Extract Button ID",
        "func": "msg.payload = String(msg.payload[2]);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1070,
        "y": 380,
                "0c779c63ceee7d51"
        "id": "4c1e56bac57b1c42",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2510,
        "y": 20,
        "id": "d56fe51869f9e45a",
        "type": "comment",
        "x": 2540,
        "y": 400,
        "id": "4deff35a28f1ce03",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1000,
        "y": 340,
        "id": "ff1ce9ad05f1a132",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 2140,
        "y": 80,
                "8850e0187eacc6d3"
        "id": "8850e0187eacc6d3",
        "type": "function",
        "func": "msg.payload = 't0.txt=\"Hello\"';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2320,
        "y": 80,
                "4c1e56bac57b1c42",
                "94a2dac7d9f23039"
        "id": "ac0492e69b2f65f5",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 2150,
        "y": 140,
                "8850e0187eacc6d3"
        "id": "f527860f.a985e8",
        "type": "serial-port",
        "serialport": "/dev/ttyS0",
        "serialbaud": "9600",
        "databits": "8",
        "parity": "none",
        "stopbits": "1",
        "waitfor": "",
        "newline": "5",
        "bin": "bin",
        "out": "interbyte",
        "addchar": "false",
        "responsetimeout": ""
Thanks for your help
Alex
as simple as possible
OK... after more hours then I should admit too :woozy_face: I remembered why I am not that fond of the Nextion. It can be a bit of a pain to use.
All I was getting was random buffers from buttons and nothing I sent was working either.
Anyhow, once I realized I was using the wrong BAUD rate :astonished: (mine is apparently set for 115200) everything started making sense and working.
Try this for sending text (and numbers if you add such a field on your HMI program)
[{"id":"4fbb5e130de7fcfc","type":"serial out","z":"e3ddcb330c2f0550","name":"NEXTION","serial":"f527860f.a985e8","x":1220,"y":180,"wires":[]},{"id":"28ecfd2672cce327","type":"debug","z":"e3ddcb330c2f0550","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1230,"y":100,"wires":[]},{"id":"6d14d3d60fea3839","type":"inject","z":"e3ddcb330c2f0550","name":"Hello World","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":830,"y":60,"wires":[["b647a6646b395311"]]},{"id":"b647a6646b395311","type":"function","z":"e3ddcb330c2f0550","name":"","func":"msg.payload = 't0.txt=\"Hello World\"';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":60,"wires":[["28ecfd2672cce327","4fbb5e130de7fcfc"]]},{"id":"fc00376ed85755ca","type":"inject","z":"e3ddcb330c2f0550","name":"How are you doing?","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":850,"y":100,"wires":[["a8858050d5125c05"]]},{"id":"a8858050d5125c05","type":"function","z":"e3ddcb330c2f0550","name":"","func":"msg.payload = 't0.txt=\"How are you doing?\"';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":100,"wires":[["28ecfd2672cce327","4fbb5e130de7fcfc"]]},{"id":"41612ead756b93af","type":"inject","z":"e3ddcb330c2f0550","name":"123456789","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":820,"y":200,"wires":[["d2632cd42c107210"]]},{"id":"d2632cd42c107210","type":"function","z":"e3ddcb330c2f0550","name":"","func":"msg.payload = 'n0.val=123456789';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":200,"wires":[["4fbb5e130de7fcfc","28ecfd2672cce327"]]},{"id":"b1bded91d84376a3","type":"inject","z":"e3ddcb330c2f0550","name":"Clear Number","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":830,"y":240,"wires":[["c90183b377cba632"]]},{"id":"c90183b377cba632","type":"function","z":"e3ddcb330c2f0550","name":"","func":"msg.payload = 'n0.val=0';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":240,"wires":[["4fbb5e130de7fcfc","28ecfd2672cce327"]]},{"id":"055d72891965fc59","type":"inject","z":"e3ddcb330c2f0550","name":"Clear Text","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":820,"y":140,"wires":[["b7e74b9c82ee3f30"]]},{"id":"b7e74b9c82ee3f30","type":"function","z":"e3ddcb330c2f0550","name":"","func":"msg.payload = 't0.txt=\"\"';\nvar textBuf = Buffer.from(msg.payload, 'ascii');\nvar postFixBuf = new Buffer(\"FFFFFF\", \"hex\");\n\nmsg.payload = Buffer.concat([textBuf, postFixBuf]);\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":140,"wires":[["28ecfd2672cce327","4fbb5e130de7fcfc"]]},{"id":"f527860f.a985e8","type":"serial-port","serialport":"/dev/ttyS0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","waitfor":"","newline":"5","bin":"bin","out":"interbyte","addchar":"","responsetimeout":""}]
thanks for your help, so nice to get.
I´ve tried to change to 115200 but if i the RPI recieve an event, the string is empty.
So i can recieve in 9600, everything is right. but to send the comes even with your json part:
What dows the Type error mean?
Thank you really much much for your help :slight_smile:
Alex
Dear my friend.
Got it
Dam it
Thats It.
I change in the ```
cmdline.txt
 115200 baut
restart and go in nodered to Nextion (serial)
![image|377x500](upload://wgIFX1FRO9KZO76GyA4t9tDd8PK.png)
 clear the output
The idea i do have it from this :slight_smile:
https://discourse.nodered.org/t/send-buffer-over-usb-serial-node/16494
Working fine, everything
Thanks folks, you are the one :slight_smile:
Alex
After the triple backticks here, your post wasn't processed properly, so unsure of you intended to post a similar image...
But good you figured it out. I forgot to add that part into my post, about Nextion needing that one field clear instead of the default false
