Add option to editor group config to disable the nodes in the group
If you right click on a group outline or name, then Show action list, you can choose "Enable selected nodes" or "Disable selected nodes" which will affect all of the nodes inside the group.
Can a button Enabled/Disabled be added to the group config dialog (cf the dialog to edit a node or a tag), which will have the same effect?
For consistency, this would be reasonable.
In the meantime, you can use the existing context menu
Additionally, the help button should be present too (if the group has documentation)
Thanks for that, I was not aware of that option.
Maybe then the group option context menu needs Enable and Disable selected nodes too?
