Add value into a row of a CSV and append to Next Line
I am given a CSV file where the first column should have ID numbers that will be filled in when scanned, but for now I am just using a timestamp to test. The current flow I have made makes every row have the same ID number, but I just want to append to the next empty value to add another ID.
I am given the CSV:
ID,PART#,BIN_QTY
,HHCS 1/4-20X1/2,300
,HHCS 1/4-20X3/4,300
,HHCS 1/4-20X1,300
,HHCS 1/4-20X1-1/4,250
,HHCS 1/4-20X1-1/2,250
,HHCS 1/4-20 X 1-3/4,250
,HHCS 1/4-20X2,250
I want to add to the first line an ID, and then append to the next line for when I inject a new ID to the next item.
ID,PART#,BIN_QTY
ef0087654,HHCS 1/4-20X1/2,300
,HHCS 1/4-20X1,300
,HHCS 1/4-20X2,250
Currently my flow just makes every single item the same ID with an output of
ID,PART#,BIN_QTY
ef0087654,HHCS 1/4-20X3/4,300
ef0087654,HHCS 1/4-20X1,300
ef0087654,HHCS 1/4-20X1-1/4,250
ef0087654,HHCS 1/4-20X1-1/2,250
ef0087654,HHCS 1/4-20 X 1-3/4,250
ef0087654,HHCS 1/4-20X2,250
Here is my flow:
        "id": "c57f2b0221605a05",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "6a6eec79effcd4d0",
        "type": "switch",
        "z": "c57f2b0221605a05",
        "name": "Check if RFID in CSV",
        "property": "payload.ID",
        "propertyType": "msg",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 640,
        "y": 140,
                "1eafbadef8d616a6"
                "e742531873290a04"
        "id": "1eafbadef8d616a6",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload.ID",
                "pt": "msg",
                "to": "rfidhex",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 890,
        "y": 120,
                "e742531873290a04"
        "id": "b55dce2557437759",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "v": "rfidhex",
                "vt": "flow"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 140,
                "cb0fe7f35da038ad"
        "id": "e742531873290a04",
        "type": "join",
        "mode": "auto",
        "build": "object",
        "property": "payload",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": "false",
        "timeout": "",
        "count": "",
        "reduceRight": false,
        "x": 1110,
        "y": 140,
                "2f77e0fa882b503f"
        "id": "cb0fe7f35da038ad",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "ID,PART#,BIN_QTY\n,HHCS 1/4-20X1/2,300\n,HHCS 1/4-20X3/4,300\n,HHCS 1/4-20X1,300\n,HHCS 1/4-20X1-1/4,250\n,HHCS 1/4-20X1-1/2,250\n,HHCS 1/4-20 X 1-3/4,250\n,HHCS 1/4-20X2,250\n,HHCS 1/4-20X2-1/4,200\n,HHCS 1/4-20X2-1/2,200\n,HHCS 1/4-20X2-3/4,150\n,HHCS 1/4-20X3,150\n,HHCS 1/4-20X3-1/2,100\n,HHCS 1/4-20X4,100\n,HEXNUT 1/4-20,500\n,FW 1/4,500\n,LW 1/4,500\n",
        "output": "str",
        "x": 300,
        "y": 140,
                "8db3881ef68fadf3"
        "id": "c38f36f021396e7f",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "template": "This is the payload: {{payload}} !",
        "output": "str",
        "x": 1380,
        "y": 140,
        "id": "673b13b3dc1ead54",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "ef0087654",
        "payloadType": "str",
        "x": 150,
        "y": 60,
                "ead1e44319b2ef3f"
        "id": "ead1e44319b2ef3f",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "rfidhex",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 340,
        "y": 60,
        "id": "6a0652a1d9127c4f",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1430,
        "y": 220,
        "id": "8db3881ef68fadf3",
        "type": "csv",
        "sep": ",",
        "hdrin": true,
        "hdrout": "none",
        "multi": "one",
        "ret": "\\n",
        "temp": "ID,PART#,BIN_QTY",
        "skip": "0",
        "strings": true,
        "include_empty_strings": false,
        "include_null_values": true,
        "x": 450,
        "y": 140,
                "6a6eec79effcd4d0"
        "id": "2f77e0fa882b503f",
        "type": "csv",
        "sep": ",",
        "hdrin": true,
        "hdrout": "all",
        "multi": "one",
        "ret": "\\n",
        "skip": "0",
        "strings": true,
        "include_null_values": false,
        "x": 1230,
        "y": 140,
                "c38f36f021396e7f",
                "6a0652a1d9127c4f"
Every line the ID is null. Might be best to output the whole array of objects and target the object in index 0.
e.g.
[{"id":"b55dce2557437759","type":"inject","z":"c57f2b0221605a05","name":"","props":[{"p":"index","v":"0","vt":"num"},{"p":"topic","v":"rfidhex","vt":"flow"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":120,"wires":[["cb0fe7f35da038ad"]]},{"id":"cb0fe7f35da038ad","type":"template","z":"c57f2b0221605a05","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"ID,PART#,BIN_QTY\n,HHCS 1/4-20X1/2,300\n,HHCS 1/4-20X3/4,300\n,HHCS 1/4-20X1,300\n,HHCS 1/4-20X1-1/4,250\n,HHCS 1/4-20X1-1/2,250\n,HHCS 1/4-20 X 1-3/4,250\n,HHCS 1/4-20X2,250\n,HHCS 1/4-20X2-1/4,200\n,HHCS 1/4-20X2-1/2,200\n,HHCS 1/4-20X2-3/4,150\n,HHCS 1/4-20X3,150\n,HHCS 1/4-20X3-1/2,100\n,HHCS 1/4-20X4,100\n,HEXNUT 1/4-20,500\n,FW 1/4,500\n,LW 1/4,500\n","output":"str","x":400,"y":120,"wires":[["8db3881ef68fadf3"]]},{"id":"8db3881ef68fadf3","type":"csv","z":"c57f2b0221605a05","name":"","sep":",","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"ID,PART#,BIN_QTY","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":true,"x":550,"y":120,"wires":[["eb8e226688c57eb0"]]},{"id":"eb8e226688c57eb0","type":"switch","z":"c57f2b0221605a05","name":"","property":"payload[msg.index].ID","propertyType":"msg","rules":[{"t":"null"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":120,"wires":[["1eafbadef8d616a6"],["2f77e0fa882b503f"]]},{"id":"1eafbadef8d616a6","type":"change","z":"c57f2b0221605a05","name":"","rules":[{"t":"set","p":"payload[msg.index].ID","pt":"msg","to":"rfidhex","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":100,"wires":[["2f77e0fa882b503f"]]},{"id":"2f77e0fa882b503f","type":"csv","z":"c57f2b0221605a05","name":"","sep":",","hdrin":true,"hdrout":"all","multi":"one","ret":"\\n","temp":"ID,PART#,BIN_QTY","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1130,"y":120,"wires":[["6a0652a1d9127c4f"]]},{"id":"6a0652a1d9127c4f","type":"debug","z":"c57f2b0221605a05","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":260,"wires":[]}]
[edit] Forgot null check.
I could not remember the index syntax, thank you for the refresher.
