you can use javascript's map command and add the id in the array of objects
msg.payload = msg.payload.map((el, index) => { return { id: index + 1, ...el } }) return msg;
Example Flow:
[{"id":"5a497eb3900dcd92","type":"inject","z":"54efb553244c241f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":350,"y":840,"wires":[["7dc1c5b4e73b459f"]]},{"id":"5f9fbd8a7188b524","type":"csv","z":"54efb553244c241f","name":"","sep":",","hdrin":"","hdrout":"none","multi":"mult","ret":"\\n","temp":"col1,col2","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":710,"y":840,"wires":[["1afc916faaef506b"]]},{"id":"7dc1c5b4e73b459f","type":"template","z":"54efb553244c241f","name":"","field":"payload","fieldType":"msg","format":"text","syntax":"mustache","template":"1,2\n11,22\n111,222\n1111,2222","output":"str","x":520,"y":840,"wires":[["5f9fbd8a7188b524"]]},{"id":"1bb9aa311187c971","type":"debug","z":"54efb553244c241f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1030,"y":840,"wires":[]},{"id":"1afc916faaef506b","type":"function","z":"54efb553244c241f","name":"","func":"msg.payload = msg.payload.map((el, index) => { return { id: index + 1, ...el } })\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":860,"y":840,"wires":[["1bb9aa311187c971"]]}]
