Adding a “rotate” to the ui_numeric node?
Is it possible to add that the numbers rotating in a circle after reaching the minimum / maximum selected value?
It would be useful when need to select values which are close at the end of range (e.g. range is 1-60, first time selection is 2, second time is 58), too many clicks ...
Thx
interesting thought... def worth looking at.
"wrap" option - added to latest version in master branch on github (not yet on npm).
Thanks a lot, it works perfectly !!!
