Is there a predictable way to add a object (with object I mean button, text, gauge etc) to a existing dashboard group without having the new object put random between existing objects.
I have dashboard groups with 40+ objects and adding one object to that group is messing up the complete design.
The new object is usually placed random (?) between existing objects
Is there a way to put a new object always at a new last row of the group without disturbing the existing layout?
Or do I have to use smaller groups?
Sorry, but I know where it has to be done.
That's not my problem.
All other objects must manual moved back to where they were, individual.
That's not what I call an easy fix an easy fix.
I see. If I manually move a new item to the end of a group`s list, at least all former items are shown again just as before adding the new item. I then decide how to rearrange the group as a whole.
for example 15 rows with each 6 buttons
Aew button is randomly placed say on row 2 at position 5, all other buttons move and will not move back at the old place after I move the new button to the bottom row.
And the complete group is a mess
Mh. I have been doing it exactly this way. Just to be sure
... don't forget to deploy after making changes in dashboard item order.
Are you using a non-standard widget size?
Or have you go some custom css active?
CSS template nodes disabled (very simple color changes), no change in behavior
widget size 45 x 35
widget spacing 6 x 6
Can you select all the button nodes and export them and paste here, then we can see if we can replicate the issue.
I presume you are using the latest version of the dashboard.
Problem is that the nodes from 1 group are spread over several flows, I only can copy one flow at a time.
But here are the nodes from the flow with the most dashboard nodes.
But I have already take the plunge and added the new nodes and rearranged the layout afterwards.
Hoping that we now have all the zigbee bulbs we need. ![]()
[{"id":"14732fc1.9aa72","type":"ui_button","z":"ddfa31a6.f05fc","name":"Dreams B-U","group":"59b4cf27.75439","order":4,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Dreams BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":150,"y":60,"wires":[["f7cd96d8.a6af38"]]},{"id":"b33b9a70.c3c488","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":1,"width":2,"height":1,"name":"Dreams","label":"Broken Dreams","format":"{{msg.payload}}","layout":"row-spread","className":"","x":480,"y":60,"wires":[]},{"id":"72ab7ca.21d3a84","type":"ui_button","z":"ddfa31a6.f05fc","name":"Dreams B-D","group":"59b4cf27.75439","order":3,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Dreams BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":150,"y":100,"wires":[["e8fe1630.49a088"]]},{"id":"9d3d39e9.1aade8","type":"ui_button","z":"ddfa31a6.f05fc","name":"Dreams B-MI","group":"59b4cf27.75439","order":2,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Dreams Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":140,"y":135,"wires":[["f36be61.01bfc18"]]},{"id":"a203e37d.aa709","type":"ui_button","z":"ddfa31a6.f05fc","name":"Dreams B-MA","group":"59b4cf27.75439","order":5,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Dreams Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":160,"y":180,"wires":[["f36be61.01bfc18"]]},{"id":"11d8813d.82d52f","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":7,"width":2,"height":1,"name":"Varken","label":"Varken","format":"{{msg.payload}}","layout":"row-spread","className":"","x":450,"y":240,"wires":[]},{"id":"59042750.f57e28","type":"ui_button","z":"ddfa31a6.f05fc","name":"Varken B-U","group":"59b4cf27.75439","order":10,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Varken BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":150,"y":240,"wires":[["68ff5021.fa857"]]},{"id":"293d3cb2.c83464","type":"ui_button","z":"ddfa31a6.f05fc","name":"Varken B-D","group":"59b4cf27.75439","order":9,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Varken BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":150,"y":280,"wires":[["4a3f00b3.54954"]]},{"id":"6edecf66.49405","type":"ui_button","z":"ddfa31a6.f05fc","name":"Varken B-MI","group":"59b4cf27.75439","order":8,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Varken Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":140,"y":320,"wires":[["d19b71e6.e4c49"]]},{"id":"ec7185b0.d2f4d8","type":"ui_button","z":"ddfa31a6.f05fc","name":"Varken B-MA","group":"59b4cf27.75439","order":11,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Varken Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":360,"wires":[["d19b71e6.e4c49"]]},{"id":"7358e446.02fb1c","type":"ui_button","z":"ddfa31a6.f05fc","name":"TV B-U","group":"59b4cf27.75439","order":16,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":140,"y":420,"wires":[["259bc495.c1cdbc"]]},{"id":"f298418.f7508c","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":13,"width":2,"height":1,"name":"TV","label":"TV","format":"{{msg.payload}}","layout":"row-spread","className":"","x":470,"y":420,"wires":[]},{"id":"917b1281.18989","type":"ui_button","z":"ddfa31a6.f05fc","name":"TV B-D","group":"59b4cf27.75439","order":15,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":140,"y":460,"wires":[["8dad074a.6adb78"]]},{"id":"c46ba772.db68b8","type":"ui_button","z":"ddfa31a6.f05fc","name":"TV B-MI","group":"59b4cf27.75439","order":14,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":140,"y":500,"wires":[["c9f4bec3.ba5d8"]]},{"id":"45db7783.0d4748","type":"ui_button","z":"ddfa31a6.f05fc","name":"TV B-MA","group":"59b4cf27.75439","order":17,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tv Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":140,"y":540,"wires":[["c9f4bec3.ba5d8"]]},{"id":"66abc1f5.5096f","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamL B-U","group":"59b4cf27.75439","order":22,"width":1,"height":1,"passthru":false,"label":"","tooltip":"RaamLinks BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":150,"y":600,"wires":[["2fa3ee42.e9ed32"]]},{"id":"90d35d02.5fdee","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":19,"width":2,"height":1,"name":"RaamL","label":"Raam Links","format":"{{msg.payload}}","layout":"row-spread","className":"","x":480,"y":600,"wires":[]},{"id":"77217599.205aec","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamL B-D","group":"59b4cf27.75439","order":21,"width":1,"height":1,"passthru":false,"label":"","tooltip":"RaamLinks BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":150,"y":640,"wires":[["3096f8b1.b0f708"]]},{"id":"b7fcd8cb.51b808","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamL B-MI","group":"59b4cf27.75439","order":20,"width":1,"height":1,"passthru":false,"label":"","tooltip":"RaamLinks Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":150,"y":680,"wires":[["66a8d0f3.d4ea5"]]},{"id":"6df0778f.e4d598","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamL B-MA","group":"59b4cf27.75439","order":23,"width":1,"height":1,"passthru":false,"label":"","tooltip":"RaamLinks Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":720,"wires":[["66a8d0f3.d4ea5"]]},{"id":"13b27f8a.14466","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":37,"width":2,"height":1,"name":"Palm","label":"Palm","format":"{{msg.payload}}","layout":"row-spread","className":"","x":450,"y":800,"wires":[]},{"id":"3b4e32c3.db75de","type":"ui_button","z":"ddfa31a6.f05fc","name":"Palm B-U","group":"59b4cf27.75439","order":40,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Palm BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":140,"y":800,"wires":[["4578a954.deff18"]]},{"id":"573f01a1.7c7d2","type":"ui_button","z":"ddfa31a6.f05fc","name":"Palm B-D","group":"59b4cf27.75439","order":39,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Palm BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":140,"y":840,"wires":[["8fa6d17a.10db3"]]},{"id":"dbfc86c0.6892a8","type":"ui_button","z":"ddfa31a6.f05fc","name":"Palm B-MI","group":"59b4cf27.75439","order":38,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Palm Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":150,"y":880,"wires":[["317865f8.1b78ba"]]},{"id":"6ea7929d.c7f3bc","type":"ui_button","z":"ddfa31a6.f05fc","name":"Palm B-MA","group":"59b4cf27.75439","order":41,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Palm Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":920,"wires":[["317865f8.1b78ba"]]},{"id":"2b1c3df7.07f532","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":43,"width":2,"height":1,"name":"","label":"Tafel","format":"{{msg.payload}}","layout":"row-spread","x":450,"y":980,"wires":[]},{"id":"b90ce062.95034","type":"ui_button","z":"ddfa31a6.f05fc","name":"Tafel B-U","group":"59b4cf27.75439","order":46,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tafel BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":140,"y":1000,"wires":[["b829e8f8.5ebe88"]]},{"id":"53b09b84.47a1d4","type":"ui_button","z":"ddfa31a6.f05fc","name":"Tafel B-D","group":"59b4cf27.75439","order":45,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tafel BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":140,"y":1040,"wires":[["d59a8eed.eeba"]]},{"id":"a45532d6.8ab2f","type":"ui_button","z":"ddfa31a6.f05fc","name":"Tafel B-MI","group":"59b4cf27.75439","order":44,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tafel Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":140,"y":1080,"wires":[["e4082113.92dbb"]]},{"id":"9a4b736e.71a8a","type":"ui_button","z":"ddfa31a6.f05fc","name":"Tafel B-MA","group":"59b4cf27.75439","order":47,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tafel Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":1120,"wires":[["e4082113.92dbb"]]},{"id":"5ad8e3dc.98fc0c","type":"ui_button","z":"ddfa31a6.f05fc","name":"Deur B-U","group":"59b4cf27.75439","order":52,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Deur BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":140,"y":1180,"wires":[["f973f24f.4c50a"]]},{"id":"8148aa2d.c50868","type":"ui_button","z":"ddfa31a6.f05fc","name":"Deur B-D","group":"59b4cf27.75439","order":51,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Deur BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":140,"y":1220,"wires":[["2a3b434d.71c93c"]]},{"id":"d8ee03a.c0152","type":"ui_button","z":"ddfa31a6.f05fc","name":"Deur B-MI","group":"59b4cf27.75439","order":50,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Deur Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":150,"y":1260,"wires":[["1081bb88.824494"]]},{"id":"d9a41c99.63521","type":"ui_button","z":"ddfa31a6.f05fc","name":"Deur B-MA","group":"59b4cf27.75439","order":53,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Deur Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":1300,"wires":[["1081bb88.824494"]]},{"id":"3a9346ae.9fe8fa","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":49,"width":2,"height":1,"name":"Deur","label":"Deur","format":"{{msg.payload}}","layout":"row-spread","className":"","x":470,"y":1180,"wires":[]},{"id":"de58a58a.4e2538","type":"ui_button","z":"ddfa31a6.f05fc","name":"Koffie B-U","group":"59b4cf27.75439","order":58,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Koffie BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":140,"y":1360,"wires":[["5feb2f29.ee6eb"]]},{"id":"ed27029f.9b6a4","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":55,"width":2,"height":1,"name":"KoffieL","label":"Koffie Licht","format":"{{msg.payload}}","layout":"row-spread","className":"","x":470,"y":1360,"wires":[]},{"id":"d26fbf3f.b499e","type":"ui_button","z":"ddfa31a6.f05fc","name":"Koffie B-D","group":"59b4cf27.75439","order":57,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Koffie BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":140,"y":1400,"wires":[["1cc8ac9e.cc2c93"]]},{"id":"b91365fa.6fdca8","type":"ui_button","z":"ddfa31a6.f05fc","name":"Koffie B-MI","group":"59b4cf27.75439","order":56,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Koffie Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":150,"y":1440,"wires":[["f9fce975.c499b8"]]},{"id":"4aa8052e.c825fc","type":"ui_button","z":"ddfa31a6.f05fc","name":"Koffie B-MA","group":"59b4cf27.75439","order":59,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Koffie Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":1480,"wires":[["f9fce975.c499b8"]]},{"id":"8bc94cddf065ba0f","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamM B-U","group":"59b4cf27.75439","order":28,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":150,"y":1575,"wires":[["93ba516dc407f0a0"]]},{"id":"eec9e0151aa7eaf6","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":25,"width":2,"height":1,"name":"RaamM","label":"Raam Midden","format":"{{msg.payload}}","layout":"row-spread","className":"","x":399,"y":1575,"wires":[]},{"id":"2bce2ced83ca2bbe","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamM B-D","group":"59b4cf27.75439","order":27,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":150,"y":1615,"wires":[["7ca533654df0fb95"]]},{"id":"6436e4bb9862823f","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamM B-MI","group":"59b4cf27.75439","order":26,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":150,"y":1655,"wires":[["ad99841583d7359c"]]},{"id":"3cdb0c3e9b39d0b1","type":"ui_button","z":"ddfa31a6.f05fc","name":"RaamM B-MA","group":"59b4cf27.75439","order":29,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tv Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":160,"y":1695,"wires":[["ad99841583d7359c"]]},{"id":"b6c68d8b8a787a12","type":"ui_button","z":"ddfa31a6.f05fc","name":"BalconD B-U","group":"59b4cf27.75439","order":34,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessUp","color":"","bgcolor":"","className":"","icon":"fa-arrow-up","payload":"DimmerUp","payloadType":"str","topic":"","topicType":"str","x":150,"y":1770,"wires":[["211c0f5f691b81b4"]]},{"id":"7c82cf32d1e4e6ab","type":"ui_button","z":"ddfa31a6.f05fc","name":"BalconD B-D","group":"59b4cf27.75439","order":33,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV BrightnessDown","color":"","bgcolor":"","className":"","icon":"fa-arrow-down","payload":"DimmerDown","payloadType":"str","topic":"","topicType":"str","x":150,"y":1810,"wires":[["2ed119ca86f665f0"]]},{"id":"48ba73e14b611270","type":"ui_button","z":"ddfa31a6.f05fc","name":"BalconD B-MI","group":"59b4cf27.75439","order":32,"width":1,"height":1,"passthru":false,"label":"","tooltip":"TV Brightness 1","color":"","bgcolor":"","className":"","icon":"brightness_low","payload":"1","payloadType":"num","topic":"","topicType":"str","x":160,"y":1850,"wires":[["d521ac5e5dfcb790"]]},{"id":"6f6942c62d78c9ae","type":"ui_button","z":"ddfa31a6.f05fc","name":"Balcon B-MA","group":"59b4cf27.75439","order":35,"width":1,"height":1,"passthru":false,"label":"","tooltip":"Tv Brightness 9","color":"","bgcolor":"","className":"","icon":"brightness_high","payload":"10","payloadType":"num","topic":"","topicType":"str","x":150,"y":1890,"wires":[["d521ac5e5dfcb790"]]},{"id":"444e7234cedc46c4","type":"ui_text","z":"ddfa31a6.f05fc","group":"59b4cf27.75439","order":31,"width":2,"height":1,"name":"BalconD","label":"Balcon Deur","format":"{{msg.payload}}","layout":"row-spread","className":"","x":405,"y":1770,"wires":[]},{"id":"59b4cf27.75439","type":"ui_group","name":"Brightness","tab":"eedb76b8.8c13a8","order":2,"disp":true,"width":"7","collapse":false,"className":""},{"id":"eedb76b8.8c13a8","type":"ui_tab","name":"Woonkamer","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Which versions of node red and the dashboard are you using?
node-red v 2.2.2
dashboard 3.1.6
