Adding node-red for each user on a iot platform
Hi im in the starting point of adding node-red for each user on my iot platform.
I know that arduino cloud haves this services, you create your user and the you have your own instance of node red.
The idea like them, is to give to each user the possibility to edit the logic flow with low code and when you login to the web page you can access your unic nodes you have.
it a possible thing to do ? or we are talking of a impossible task ?
thanks a lot.
You can achieve that using FlowForge (like node-red it is open source)
FlowForge also has a hosted platform that does exactly what you describe right now.
