Advice for an MQTT/NR controlled EV charger
Does anyone have experience with an EV car charger that I can control via Node RED and/or MQTT? I know there is something to read out an Easee Home Charger (https://flows.nodered.org/node/@runnane/node-red-contrib-easee) but (also) this charger has limited home automation capabilities.
I would like to read which chargers are eligible, thanks in advance.
Might not be quite the same but:
Thanks, that's definitely an interesting project. If I am right the maker uses a DIN Rail Mounted Metering solution, unfortunately no EV charger with MQTT.
No, probably not. Though I think some cars give you access to data and possibly control.
I spotted a few videos about IoT and car charging - not sure if any include MQTT but if you can intercept the data, adding in MQTT should be pretty easy.
https://www.youtube.com/results?search_query=iot+control+car+charging
Thanks for the link to the video. If anyone has any ideas, I'd love to hear them.
There is the openWB Project, which makes a wallbox with open source software, which also has a MQTT Interface for all of the data and also has an "intelligence" for solar charging
That is an interesting charger, unfortunately a bit expensive for private use.
