Hello, i have the node toggel install, over the console.
The feadbeck, install 1 packed.
But i don't find the in NodeRed.
Where can i find it?
If you want a node to use in node-red then you have to find a node-red node and install it and you should use the flows tab here on the forum to search for one and if you don't find one, you will have to build one yourself r get someone to build it.
Try using the palette search:
Do you see the node?
Make sure you have installed the 'toggle' node using the Palette manager and then you should be able to use it in your Node-RED flow using the Palette search as mentioned by @jbudd.
It seems possible that @Marccore was trying to say
npm install node-red-contrib-toggleIn which case maybe they omitted the first step cd .node-red
Sadly that is just guesswork.
Hello, i install with this syntax
This Node:
node-red-contrib-toggle 0.1.1
Hello, i dont have the Palette Manager. Why?
No i dont see the den Node
No the Manager is not to see.
I install node red yesterday.
On my old installation i have the manger .
And it works
Well that seems to indicate your 'install' failed in some way or another.
You'll probably have to explain how you performed the install and on what hardware (so people can help).
I don't know.
But yesterday on two of my Linux computers there was no "Manage Palette" in the hamburger menu.
I reinstalled Node-red using the Raspberry pi install script and the problem was resolved.
OK.
Installaed on the rasberian OS lite
This Pi is running only for the I/O Broker
Node.js Version 20.11.1
NR 3.1.5
NPM i dont know
Cool, thanks.
I make an test laster, and reinstall
This is a fresh new SD Card with the installation.
So I have solve the problem.
Its only a checkbox in the I/O Broker.
Hello Dave,
now i have the next question.
I want to make a toggle my lights
I read you document "Having some FUN with Node-RED buttons"
I have tested the If loop.
How can i check if change?
The Code do not run
The Code:
if (msg.payload == "change") {
msg.payload = 0;
You can create a toggle in the function node, this topic may help. Convert one value into two different ones
What you have shared is only part of the code in a function node in a very old thread of mine.
Can you share the Node-RED flow you have created so far?
